Removing the afc
Removing the afc
Postby GO OVRIT » Mon Jan 21, 2008 8:46 pm
So how streetable is the pump with no afc? I can train myself to drive just about anything, but occasionaly the wife or my little brother might get their feet on the pedals. What are the side effects on an allaround driver/hauler/play toy? Thanks, Mike
GO OVRIT
Postby DTanklage » Mon Jan 21, 2008 11:03 pm
side effects: increase of fuel sufficient to create an extra 3 or 4 psi boost
that is assuming you already have a fully ground cone
from stock cone to no afc would be even more noticable
the fuel is avail as soon as you are off idle tho, so the pedal is that much more touchy
whats done to your cone now?
DTanklage
Postby DTanklage » Mon Jan 21, 2008 11:11 pm
ps - forgot the biggest side effect: make big smile on face!
unless your inj are too big and your turbo 2 small?
DTanklage
Postby bigbaddually » Mon Jan 21, 2008 11:18 pm
How noticable would it be with a stock cone and stock injectors on a 92 intercooled?
92 250 4x4 5 speed, 10" lift, 39" military's, 4.56's, detroit lockers, timing 1/8", Isspro boost and pyro.
95 3500 4x4, DTT billit trans, timing at 15.5*, #5 plate, boost elbow, k&n, straight pipe, Autometer boost,trans,pyro.
bigbaddually
Postby DTanklage » Mon Jan 21, 2008 11:21 pm
never tried it, green leaf would be the one to ask, but i imagine it would wake that thing right up
if you dont like it just put it back in
DTanklage
Postby cummins king » Tue Jan 22, 2008 6:39 am
i have a 93 ic, that i did it to, and you get maby 2 pounds of boost and a bit more botom end smoke and torque, but its not as mush as dt truck due to the small injectors that come with the ic trucks, you will have no proble diving it on the street
93 4X4 auto
cummins king
