HX40W??
HX40W??
Postby CumminsPride » Sat Feb 02, 2008 10:47 pm
HX40 with a 16CMgated housing, Will the exhaust housing interchange with a HX35 turbo? I have one with a 12 and I'd like to use a 16 off this junk 40 I have.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby rockjeep73 » Sun Feb 03, 2008 12:49 am
no, it wont interchange. HX40 runs a larger exhaust wheel than a 35
2000 QCLB 2500 4x4, 12.05 @ 111
89 D-250, In The Graveyard
89 W-250, Mostly Stock
http://www.SHSDiesel.com
rockjeep73
Postby CumminsPride » Sun Feb 03, 2008 5:47 am
Well that sucks. Whats a 16cm gated HX40 housing worth in like new condition?
CumminsPride
Postby Philip » Sun Feb 03, 2008 10:30 am
There is a brand new one on ebay right now. He has a starting price of $150 and hasn't gotten a bid yet.
I wish that was a 14cm you had.
Postby cummins king » Sun Feb 03, 2008 11:22 am
i pyed 200, 250 shipped for a new rebiuld with 16cm
93 4X4 auto
cummins king
Postby GO OVRIT » Sun Feb 03, 2008 12:24 pm
It can be modified to work. I was told that the 14 on my hx 40 was bored out. What do you want for the 16?
GO OVRIT
Postby cummins king » Sun Feb 03, 2008 1:23 pm
hey GO what type of boost are you making with the hx40
93 4X4 auto
cummins king
Postby GO OVRIT » Sun Feb 03, 2008 10:31 pm
Hopefully I'll let you know by the end of the week. My backing plate gasket should be in by then.
GO OVRIT
Postby ford69557ci » Sun Feb 03, 2008 11:07 pm
dont get it much over 50 psi thats when the 3 i killed started to come apart. 2 broken shafts one exploded compressor wheel.
ford69557ci
Postby cummins king » Mon Feb 04, 2008 6:21 am
is that with twins ford, even so ith twins i could probaly biuld 90psi of boost :evil:
93 4X4 auto
cummins king
Postby ford69557ci » Mon Feb 04, 2008 9:41 am
no that was just a single 40 on my p pump truck i used to have i have friends that have blown several up to
ford69557ci
Postby GO OVRIT » Sat Feb 09, 2008 10:06 pm
cummins king wrote:hey GO what type of boost are you making with the hx40
I put it o today, alomg with the intercooler and cooler tubez. 35 psi was the most I saw, which is about what I expected with the stock injectors. Its actually got a lot less lag than the 21 cm h1c.
GO OVRIT
Postby cummins king » Sun Feb 10, 2008 7:10 am
o got to test mine out on friday, i was able to get to 32psi, i acualy think its got less lag then my 16cm h1c, it flys right up there, but now its got to sit there for awhile, my botom turbo was just pucking out oil :cry:
93 4X4 auto
cummins king
Postby MMiller » Sun Feb 10, 2008 9:20 pm
I've got one on my work bench right now to put on. I've learned that the HX 40 was designed to be a good upgrade for a mild 5.9 cummins. Its not designed for an all out high boost, dyno queen, truck pulling charger. A friend of mine dyno'd last summer with a p-pumped 12 valve and ran 500+ horse and over 1200 for torque at 35 psi of boost. Then he put it with on top of another turbo.
Mine's got a 16 WGated housing. I'm liking the report where it spools better then the stock charger.
Michael
MMiller
Postby cummins king » Mon Feb 11, 2008 6:22 am
i think so anyways, i put the pettel down and 30psi is in a sec or two, but the wissle it make is loud
93 4X4 auto
cummins king
