fabing up a set of twins.
Postby GPSMatt » Tue Feb 05, 2008 1:34 pm
what kind of material are you guys using what size for the hot pipe etc.. how thick for the flanges?
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Tue Feb 05, 2008 1:46 pm
i got all of my flanges from www.sourceautomotive.biz the flanges are 1/2 plate and are very nice quality as for the hot pipe i am just usin 4" ex pipe because my turbo outlet is 4".
ford69557ci
Postby CumminsPride » Tue Feb 05, 2008 5:00 pm
Pipe supply house. Ask for hydraulic weld fittings.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby cummins king » Tue Feb 05, 2008 6:05 pm
i custom biult everything, including flanges i welded the back part of the turbo right to the hot pipe instead of making another one, i went to a regular pipe store and got a 3/8 4inch 90o, and 1 foot of 4inch 3/8 pipe and welded it all together
what i would do if i biult another set, its just a recomendation, but i would go out and get a scrape cummuns motor and biuld it on there first then put it on you truck
check my photobucket page out in my sig got lots of pic of the biuld, i shill have to get a shop to weld up my turbo to turbo pipe, i dont have the welder
93 4X4 auto
cummins king
Postby GPSMatt » Tue Feb 05, 2008 11:47 pm
ur 4 inch is 3/8 thick? ford you just used regular guage exuasht tubing for the hot pipe?
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Wed Feb 06, 2008 12:11 am
yep that its just normal 4" ex pipe i figured if its good enough for the turbo setup on my 1400hp small block and everybody elses race stuff then its good enough for this setupmine is 4"id if i used 3/8ths 4" id the od of the pipe would be to large to weld to my bottom turbo flange
ford69557ci
Postby cummins king » Wed Feb 06, 2008 7:41 am
yup 3/8's is how thick mine is might be a bit over kill but it super strong and it fit perfecly on my botom flange, exhaust piping for a down pipe is not strong enough it will crack, diesel burn way hotter then gas does Ford
93 4X4 auto
cummins king
Postby GPSMatt » Wed Feb 06, 2008 10:16 am
wow 3/8 is real thick is that normal for people to use that size? I am doing everything out of stainless does that make much of a diff on the hot pipe?
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Wed Feb 06, 2008 2:08 pm
on a full quarter pass my egts may be at 1600 with a really not tune. my friend says at the end of the tracck he can see my dp and headers glowin orange. horsepower makes the heat and at 1400hp there is plenty of heat.
ford69557ci
Postby GO OVRIT » Wed Feb 06, 2008 4:34 pm
3/8"s is huge. I don't have that thick of dom tubing for the exocage on a jeep. You're not worried about all that weight on the manifold?
GO OVRIT
Postby CumminsPride » Wed Feb 06, 2008 8:20 pm
Most are 1/4 and the wieght is carried by the bottom turbo support too. Standard pipe won't last if there is any kind of bind. Once it cools and shrinks it will crack and become brittle at the flanges.
CumminsPride
Postby ford69557ci » Thu Feb 07, 2008 12:41 am
the way i am buildin mine there is no bind at all im not new to the turbo game so i know how to set stuff up and make it last. my large turbo is goin to be mounted on the inner fender with a support off the engine kinda like schieds sets up some of thier stuff
ford69557ci
Postby GPSMatt » Thu Feb 07, 2008 1:15 am
what is a good source for the quarter inch wall tubing for hte hot pipe
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby CumminsPride » Thu Feb 07, 2008 5:35 am
Pipe supply house. Ask for hydraulic weld fittings. This stuff is not easily found on the web so get out your yellow pages and call supply houses or mechanical companies that deal with hydraulics.
CumminsPride
Postby cummins king » Thu Feb 07, 2008 6:16 am
CP is right its redaly avalable from a pipe place, and any where, wheir they sell fire hidrent piping will also work
93 4X4 auto
cummins king
