Dual VE's????
Dual VE's????
Postby mhuppertz » Sat Feb 09, 2008 9:38 pm
Anyone ever tried chain driving a second VE off of the gear for the primary and then merged the lines as they go into the injectors?
mhuppertz
Postby JQmile » Sun Feb 10, 2008 12:39 am
Workin on it...still in the design stages...Scheid does build injectors that could be used, that are normally used for the mod pullers that run 12cyl p-pumps...they have two feeds. Was thinking of a transfer-case style drive off the original pump drive that would drive both pumps...I'll let ya know if anything happens.
JQmile
Postby cummins king » Sun Feb 10, 2008 7:05 am
yes thats called dual feed injectors, i know 2 ve's sound cool in all but, why wouldnt you just go to a p pump, 1 p pump would still out preform 2 ve's, and the cost would be less
93 4X4 auto
cummins king
Postby mhuppertz » Sun Feb 10, 2008 9:08 am
cummins king wrote:yes thats called dual feed injectors, i know 2 ve's sound cool in all but, why wouldnt you just go to a p pump, 1 p pump would still out preform 2 ve's, and the cost would be less
2 VE's give you all sorts of possibilities related to the mechanical advance that the P pump does not have. Also you can slightly stagger the pump timings for a multi pulse charge. I'm not so sure that two VE's couldn't make the same power as a P.
Besides, it would look really cool!!!
mhuppertz
Postby rbrettctd » Sun Feb 10, 2008 9:23 am
Wouldnt different timings on the 2 cause all sorts of problems?
Randy
rbrettctd
Postby mhuppertz » Sun Feb 10, 2008 10:24 am
rbrettctd wrote:Wouldnt different timings on the 2 cause all sorts of problems?
I don't know how the VE shuts the valve. Might neew a check valve...Might me a bad idea altogether.
mhuppertz
Postby cummins king » Sun Feb 10, 2008 11:16 am
if you never try you will never know, i think that they have to be timd togeter or you will let fuel in at the wrong time of the stroke
93 4X4 auto
cummins king
Postby ford69557ci » Sun Feb 10, 2008 12:49 pm
i would think that two different pump would be of calibration enough that it would cause some problems. you might be able to bench tune each one till the are perfectly in sync but after some miles then wear heat and other mechanical forces would throw them off. also there would be more drag on the timing gears trying to turn two pumps and that would not only be a power loss but might damage somethin.
ford69557ci
Postby cummins king » Sun Feb 10, 2008 12:58 pm
well put ford, any luck on thes seals yet
93 4X4 auto
cummins king
Postby mhuppertz » Sun Feb 10, 2008 1:08 pm
cummins king wrote:well put ford, any luck on thes seals yet
Screw it, I'll just put a CP3 right after my lift pump! :roll: ;)
mhuppertz
Postby cummins king » Sun Feb 10, 2008 1:13 pm
:lol: pressure just might be a small problem lol
93 4X4 auto
cummins king
Postby ford69557ci » Sun Feb 10, 2008 1:56 pm
i gotta call monday and see if its in or not i have been tryin to get the engines in my boat so the blown up trucks is on the back burner at the moment
ford69557ci
Postby cummins king » Sun Feb 10, 2008 3:18 pm
ya no problem, see if you can get the part number when you call them, im now kind of in a rush since i blow out my seal on my pump, i can get a spring loaded seal but then i have to mashine out hole bigger
thanks
93 4X4 auto
cummins king
Postby ford69557ci » Sun Feb 10, 2008 3:21 pm
i thought you did the snap ring thing?? with the ring my factory style seal will hold around 40psi with no problems
ford69557ci
Postby cummins king » Sun Feb 10, 2008 3:59 pm
ya that pump is still sitting on the bech waiting for a hd seal and cam plate
93 4X4 auto
cummins king
