by KTA » Sun Feb 24, 2008 11:21 am
Fire rings are a solid thick metal ring that replaces the stock firering in the stock headgasket. It can be installed with no grooves for the least holding capacity, with a groove in either the head or block for more holding capacity, or with both a groove in the head and block for maximum holding capacity. The reality is the head moves around on the block from the compression, power, and vibrations created when the motor is running. This movement causes fire rings to wear against the surfaces it contacts. A stock headgasket wears against the surfaces too, but since its crush pressure is less it wears at a slower rate, it also has more contact area so that helps as well.
