Head gaskets
Head gaskets
Postby seeker1056 » Sun Feb 24, 2008 7:29 am
Whats out there for head gaskets?
Stock
Marine
Cometic
Copper
Without O-rings which will survive best on the street and pull track and tops 60 psi boost
What is the best install practise? We always used either a copper or aluminum based paint and coated both sides soaking it prior to install
Head stud a are a given.
Seems I read somewhere that Brian and a few others are runnin no o-ring and a marine gasket?
thanx
Ken
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby KTA » Sun Feb 24, 2008 9:38 am
I run a copper with fire rings. I did use a stock .020" overthick gasket when I had my B-1 single and it held up to 480hp. The .020" overthick is what is referred to as the Marine. It really isn't a Marine, its just an overthick stock, and the marine 370hp from the factory uses the same gasket as a 160hp truck motor. The word on the street on the Cometic is it shouldn't have been released as the design is flawed and won't hold. Fire rings will hold your most power, followed by o-rings with a stock gasket. I think the o-rings are a better solution for a street motor as the firerings are hard on the block and deck surfaces overtime. (50,000 hard miles)
Postby seeker1056 » Sun Feb 24, 2008 10:35 am
what are fire rings? and what is hard on the block and head mean?
As I know nothing of any of these setups, and i bet many on here dont as well, could Brian or someone give us a rundown on what how and why to install for the various types
and where can copper and others be purchased
thanx
Ken
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby cummins king » Sun Feb 24, 2008 10:41 am
fire rings get done to the block and o rings get done to the head, copper head gasket should only be used for raceing but i beleive there is a few on here running them on street
93 4X4 auto
cummins king
Postby KTA » Sun Feb 24, 2008 11:21 am
Fire rings are a solid thick metal ring that replaces the stock firering in the stock headgasket. It can be installed with no grooves for the least holding capacity, with a groove in either the head or block for more holding capacity, or with both a groove in the head and block for maximum holding capacity. The reality is the head moves around on the block from the compression, power, and vibrations created when the motor is running. This movement causes fire rings to wear against the surfaces it contacts. A stock headgasket wears against the surfaces too, but since its crush pressure is less it wears at a slower rate, it also has more contact area so that helps as well.
Postby DTanklage » Sun Feb 24, 2008 11:39 am
that is one of the purposes of the o-ring
to keep the power ring part of the gasket from moving around
that, and they create more squish
DTanklage
Postby seeker1056 » Sun Feb 24, 2008 11:59 am
I know I read on the cummins racing site that they o-ringed the block using the Isky tool instead o the head
Isky 200-GRM Tool O-Ring Cutter for Engine Block Kit
The kit is $285 vs $300 or so to havea head done if you can find someone
Is there a pro/con to this?
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Fnschlaud4620 » Sun Feb 24, 2008 12:37 pm
I have read that it is better to have your o-ring or firering grooves cut on a mill, that way a more consistant protrusions are accomplished. I have read that the isky will not cut as deep a groove when it hits harder material, where a mill will go through it no problem.
When the casting freezes from a liquid to solid, thinner sections freeze off more quickly than thicker, so the area between the bores can be harder than rest of the area around the bores.
Personally I will do my work to the head. I like the idea of having different options for the future, and if I do decide to change my setup all I have to do is swap the head. There is added resale value to the head, and it is easier to setup on a mill to do the work.
Fnschlaud4620
Postby ford69557ci » Sun Feb 24, 2008 2:23 pm
I will be runnin a flat out gaskets rubber coated copper haead gasket with o rings in the block and reciever grooves cut in the head. these gaskets have been proven in 2500hp pro mod cars so i think they can take the power and heat. the only thing bad about copper is they require a retourque every now and then. comectics i have heard nothin good about them unless you engine is out where the block can be machined they really have problems and several people on comp diesel say thay are no better than a factory gasket maybe worse. no one has tried the comectic fuzion which is thier race gasket???
ford69557ci
Postby Begle1 » Fri Feb 29, 2008 1:46 pm
KTA wrote:Fire rings will hold your most power, followed by o-rings with a stock gasket. I think the o-rings are a better solution for a street motor as the firerings are hard on the block and deck surfaces overtime. (50,000 hard miles)
How much experience is that statement based on? I hadn't heard a mileage comparison when I bought my firerings... :x
Has nobody gone over 100,000 on firerings? Or is it that your block and head are shot by the time you get there?
I haven't cut open the Haisley shrink-wrap yet, so I'm only out shipping and restocking if I change my mind.
Postby ford69557ci » Fri Feb 29, 2008 5:09 pm
I have not heard any on the milage on the fire ring setup??? But i am set on my rcc setup it holds my small blocks power and i have only done one retorque. I also ran the same rcc copper setup on a 650hp 4cyl 2.4 dsm motor with no problems or coolant leaks. I have heard of the people running the solid copper gaskets having some coolant and oil sealing issues after some miles on the street though.
ford69557ci
Postby KTA » Fri Feb 29, 2008 11:39 pm
It is based on 2 fire ringed motors with groves in the head only, that after 50000+ miles blew. When they were taken apart it looked like the rings were trying to cut grooves in the block as well. Eventually they wore enough they lost crush, and therefore containment. Maybe if they had had groves in the head and block both to begin with they would not have failed??
Postby Begle1 » Sat Mar 01, 2008 7:35 am
Seems to me, based on my vast knowledge of the subject, that if you were relying on a steel ring to seal combustion, then you would see a lot of improvement in mating the ring to the head and the block...
It seems like that's what most guys who recommend firerings over O-rings do...
Users browsing this forum: No registered users and 69 guests
