by Philip » Sun Nov 16, 2008 12:07 pm
Going to a bigger turbo you almost always loose some boost. In the holset line figure 2 PSI for each step to the larger turbo.
Right now with your truck at 38 PSI your about 15 PSI over the map range of a H1C. You making a lot of heat to build to that PSI. The HX35 has a map range of 35 PSI.You will be getting a cooler more dense intake charge.
So don't worry about a small loose of boost. Your looking for a cooler intake charge.
