HX35 on my truck.
HX35 on my truck.
Postby dodgetkboy78 » Sat Nov 15, 2008 12:21 pm
Any custom fit goodies I have to worry about? I get the downpipe with the hx35 too. The only issue I may have as far as I can see, is my pacbrake.
dodgetkboy78
Postby Ace » Sat Nov 15, 2008 2:34 pm
This kinda what a wastegated housing with a PacBrake looks like in a 1st gen. It's tight:
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_170.jpg
There's no more than about an inch of clearance to the heater box with the pipe dropping almost straight down from the Pacbrake. Later I finished the job with a full 4" model:
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_188.jpg
You will need to get the DP from Pacbrake (3") if you want it to bolt up to the bellhousing, or make a custom one like I did.
Postby dodgetkboy78 » Sat Nov 15, 2008 4:24 pm
Can I put a non wastegate housing on the hx35? I mean, I have a 16cm housing already, will it work on the hx turbo?
dodgetkboy78
Postby Ace » Sat Nov 15, 2008 5:02 pm
Then it would probably be straight swap with your existing DP. You do have the Pacbrake presently installed, right?
Postby dodgetkboy78 » Sat Nov 15, 2008 10:05 pm
Yeah, it's been there for years....... But can I put my 16cm non wastegte housing on the hx35?
dodgetkboy78
Postby Philip » Sat Nov 15, 2008 10:43 pm
The H1C and the HX35 use the same exhaust housings. If you don't want to mess with the WG'd housing just use the one you have installed.
Postby dodgetkboy78 » Sun Nov 16, 2008 1:58 am
Awesome! :D It wont hurt the performance of the HX at all will it?
dodgetkboy78
Postby Philip » Sun Nov 16, 2008 7:37 am
It will not hurt performance one bit and it also means you don't have to rework any of the exhaust.
Going to the HX from a H1 you will see a small drop in boost. Normaly it is around 2 PSI. But the EGt's will drop some at WOT. On my truck when I did the HX35 swap I had a 25 degree drop at WOT.
Switching to a 24 valve air horn or a set of cool tubz's will give you around a 50 degree drop in EGT's at WOT. I think of a HX35 as a minor upgrade.
Postby dodgetkboy78 » Sun Nov 16, 2008 11:58 am
How is a HX a upgrade if I lose boost? I can lose 50F off the egt from backing off from 38-36psi.....................your starting to give me second thoughts here............I have cooler tubes already.
dodgetkboy78
Postby Philip » Sun Nov 16, 2008 12:07 pm
Going to a bigger turbo you almost always loose some boost. In the holset line figure 2 PSI for each step to the larger turbo.
Right now with your truck at 38 PSI your about 15 PSI over the map range of a H1C. You making a lot of heat to build to that PSI. The HX35 has a map range of 35 PSI.You will be getting a cooler more dense intake charge.
So don't worry about a small loose of boost. Your looking for a cooler intake charge.
Postby dodgetkboy78 » Sun Nov 16, 2008 12:16 pm
Right-O.....
I am also thinking of getting rid of the POD's and getting some 370's.
dodgetkboy78
