ps intercooler
ps intercooler
Postby 1991cummins » Thu Jan 08, 2009 10:16 am
i have found a few... but they want to know if i want one from a vehicle with a catalytic converter or without... i dont know why it would make a difference at the intercooler, but if it does, which one do i need for the conversion?
1991cummins
Postby peobryant » Thu Jan 08, 2009 12:37 pm
You want an all aluminum intercooler from a 7.3 PowerStroke. I don't think the catalytic converter has anything to do with the intercooler. As long as its the aluminum one, it's okay.
Postby fergavs » Thu Jan 08, 2009 1:55 pm
what he said. also the 6.0l ones are fine so long as its all aluminum. no plastic tanks!!!!!
fergavs
Postby Richie O » Thu Jan 08, 2009 8:08 pm
They asked me the same thing. Some times things are different and they ask wierd questions. I remember looking up brakes for a car once and the books asked weather or not it had a sunroof. That was an easiest way to tell the suspension package the car came with. The only difference I can think of would one being plastic tanks and the other with aluminum tanks. I also know lots of times the computer will ask questions and if you take the time to look it up both ways you still get the same part number. I said "well which one do you have" they only had one so I had them pull it for me and it was the aluminum one so I bought it. I do not remember which one I ended up with. ( converter or no converter ). :roll:
Postby 1991cummins » Thu Jan 08, 2009 9:53 pm
yah, that is kinda what i figured, so idk lol... i will just have to check and see if it has the aluminum tank...
thanks guys,
Derek
1991cummins
Postby Richie O » Thu Jan 08, 2009 10:06 pm
Just get ready for a project. It is not a drop in replacement. :shock:
Postby 1991cummins » Thu Jan 08, 2009 10:14 pm
so ive heard :( but my turbo will thank me through my pyro ;)
just curious, do you, or anyone have a link to write up ace did on this?
1991cummins
Postby TWorline » Thu Jan 08, 2009 10:19 pm
[quote="just curious, do you, or anyone have a link to write up ace did on this?[/quote]
Here is a link to the write up Ace did.http://www.dieseltruckresource.com/dev/showthread.php?t=149268
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby 1991cummins » Thu Jan 08, 2009 10:23 pm
thanks tim, i appreciate it :)
derek
1991cummins
Postby Richie O » Thu Jan 08, 2009 10:48 pm
Yup, Tim's a nice guy, when he is not sniffin glue!! :lol:
Postby Richie O » Thu Jan 08, 2009 11:28 pm
I have a few pictures.
Every thing removed, holes cut for i/c tubes.
Top factory ford rubber mount.
Lower bolt mount
Cut out at top for clearence
Mounted just above frame
Cut bumper mounts for clearence and then reweld
Pipes entering
Cut radiator sides for clearence for i/c pipes
Cut , shorten and reweld secondary hood latch for clearence of cooler
when hood is closed
Installed
Installed with tube grill
There are a lot of things I did not take pictures of. I did not have room for my a/c condensor. The tranny cooler just fits behind the tube grill. I also had to rebuild the area where the cooler tubes go through the core support. The area that has to be cut is the structure part of the whole core support. This is with the non intercooled core support. It will be different then the factory i/c core supports.
Postby 1991cummins » Wed Jan 21, 2009 8:34 pm
WOW, thanks a bunch richie, those pics are a great reference! :D
1991cummins
