Biggest single on a 1st gen?
Postby JQmile » Sun Jan 11, 2009 9:22 pm
What size singles you guys running? Anybody running anything bigger than 64mm?
JQmile
Postby VEfreak » Sun Jan 11, 2009 11:32 pm
A Garrett GT4202 has been used in a puller by, i believe, stillsmokin. I believe it is a 76mm compressor wheel, maybe bigger. definately not streetable.
I AM ZUES DAMNIT
VEfreak
Postby dvst8r » Mon Jan 12, 2009 3:34 pm
The biggest 4202 has a just under 75mm compressor.
1990 W250 non ic'd. Under the knife again.
dvst8r
Postby pulltilbroke » Mon Jan 12, 2009 7:19 pm
Jeffs charger is a 74mm
Postby KTA » Tue Jan 13, 2009 11:39 am
I ran an Aurora 5000 aka K-31 for awhile. It was a 71mm.
Postby pulltilbroke » Tue Jan 13, 2009 11:44 am
I have also ran a A5K on my truck
Made good power but the clutch would'nt hold
Postby JQmile » Tue Jan 13, 2009 4:30 pm
Dang! Will those things even spool without head work or a cam?
JQmile
Postby pulltilbroke » Tue Jan 13, 2009 8:44 pm
Why yes they will :D
Postby dvst8r » Wed Jan 14, 2009 10:20 am
I have this GT4294 sitting in my garage, it is just the small one 70mm compressor wheel.
My truck is just a toy, I rarely pull anything and if I do it is just a couple sleds, or an open deck trailer with a car.
I have really been debating a lot lately of just getting a tight T4 hotside for the gt4294 and running it as a single vs leaving the big t6 hotside on it and running it as a primary, or not using it at all and just run the HT60 as a primary.
The big single is just so easy, and there is so much room for it. The twins are so much more time, but are probably a lot more drivable.
Decisions, decisions. :roll:
dvst8r
Postby Richie O » Wed Jan 14, 2009 10:49 am
With those big turbo's isn't it easy to fall off charger if your rpm's come down under full load. I see alot of pulling videos and when the rpm's pull down a little the charger gives up and they are all done. Doesn't twins take care of this?
Postby seeker1056 » Sun Jan 18, 2009 12:39 pm
for those of you that that ran an Aurora 5000 at what rpm did it start to spool, and what psi boost did they make?
Sounds like it might make a good pullin turbo for me
also any thoughts on this turbo
http://cgi.ebay.ca/ws/eBayISAPI.dll?Vie ... %26otn%3D1
thanx
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Cschafer » Mon Feb 02, 2009 7:58 am
silver bullit actually spools quite well, with an auto it would probobly even be fun on the street but I think the big turbo's don't work as well with the power range of the ve 12v. My 62 makes more seat of the pants power then the 66. I think I have mine fueling higher than most, no defuel up to 3600 where I let off (stock valve springs) but the sweet spot for power sure seems to be between 1700 to 2700. The 66 wasnt happy till about 2000 after some tuning. I think that KTA and stomp would agree since there both running setups that I'm guessing come in at or before 1600.
91 w250 wrecker
Cschafer
Postby seeker1056 » Mon Feb 02, 2009 10:47 am
yah my prostreet 66 doesnt spool reeal good till around 2000 or so rpm, but then hang on cuz once it lites its gone - 45 psi boost instantly
About to try a Pro52 which is a 71 mm charger tha tHolset makes just for things like pullin so we will see how well it works for a VE shortly
I think Bgilbert ran one as well to make 500+/- hp
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
