Will an HX40 16cm W/G housing fit and work on a..... WH1C? If not will it go onto anything other then an HX40?
How about an aftermarket 16CM W/G housing for a WH1C, are they available, and where?
sdstriper wrote:The skinny pedal...
It would take a lot of fuel to get a 16cm^2 housing to overboost the WH1C. Enough fuel that the needle snapping off of your pyro would be more of a concern. Or, I suppose an external wastegate. I've never read about anybody needing or wanting a wastegate with a 16cm^2 housing.
