Best mods for my Motorhome?
Postby finn188 » Fri Feb 27, 2009 10:08 pm
I bought a 1992 35' motorhome with an IC Cummins and 4 speed Allison trans. It is a pusher (engine in rear). It only has 20K miles and runs great but just low on power. My goal is:
-to be able to tow my 93 Grand Cherokee on a stout 2 axle trailer (Im not sure on total weight)
-keeping the EGTs as low as possible.
-Low budget
I have been on the site for several hours and have found some good info but nothing specific to a 1st gen motorhome/ tow rig.
So after reading a bit here is my plan:
1- Pyrometer/Boost/Fuel pressure gauges
2-366 spring
3- tweak the pump
if thats not enough:
4-DDP injectors...300s?
if still not enough:
5-12 or 14 mm housing?
6- water injection
This is my first diesel. Is there any way to increase the boost at the turbo waste gate? Thanks and any input on my plan of attack is much appreciated.
finn188
Postby peobryant » Fri Feb 27, 2009 10:23 pm
If it is a '92 Cummins it will have an H1C turbo, which has no wastegate.
If you want to keep the EGT's low, I wouldn't suggest tweaking the pump. A set of injectors will give it a nice boost in power (DDP and New Era have very good reputations) and still be manageable in the EGT department.
You may also want to add a tranny temp gauge to your list. Don't want to cook that Ally.
Postby finn188 » Fri Feb 27, 2009 11:39 pm
'91 Cummins wrote:If it is a '92 Cummins it will have an H1C turbo, which has no wastegate.
New plan:
1- guages
2- 366 spring
3- DDP or New Era injectors
Any idea on the numbers I could expect with these mods? Would fuel mileage suffer much? anything else I should do?
finn188
Postby sdstriper » Sat Feb 28, 2009 1:37 am
Was this a swapped in engine or is it factory? Can you get to the engine identification tag on the gearcase? If so, check the rated HP, same with the turbo, there is a tag on the turbo, ID the turbo and engine then report back.
Just because it is a 92' doesn't automatically mean it is built exactly the same as the Dodge CTD's. Unless it was a swapped in engine from a Dodge p/u...
sdstriper
Postby peobryant » Sat Feb 28, 2009 1:49 am
sdstriper wrote:Was this a swapped in engine or is it factory? Can you get to the engine identification tag on the gearcase? If so, check the rated HP, same with the turbo, there is a tag on the turbo, ID the turbo and engine then report back.
That's exactly what I was thinking. We can't give much advice, if we aren't sure what the engine is.
Postby burnt_servo » Sat Feb 28, 2009 7:20 am
i'm wondering how much higher the stall speed of the allison converter is going to be after the engine mods ???
and it it's much higher than the engine being stock , maybe a low / lower stall converter being added to the list , much like when a guy hops up a auto dodge cummins .
'93 w250 .... stock ...
burnt_servo
Postby finn188 » Sat Feb 28, 2009 7:52 am
It is a factory setup, no mods. With the model year being 1992 and having an inter cooler I was guessing it would have the same engine as the 1992.5 pickup. I will get the ID numbers today to confirm engine/ turbo. BTW I believe the owners manual claims 160? hp and 300 ft/lbs
finn188
Postby Richie O » Sat Feb 28, 2009 8:41 am
I would not give it much power. Being that heavy you are going to be on the throttle all the time. If you can get the power you want and keep EGT's managable it still is hard on the whole drivetrain. I would keep it reliable and slow. I would not go above 225 horses. Its much better to be slow and go forever then to go fast then be broke down beside the road. :evil:
Postby MrHorsepower » Sat Feb 28, 2009 8:43 am
I have a '92 Gulfstream and it is rated at 190hp, intercooled. I will go look at the numbers it has on it tonight.
In Progress: '84 Chevy Silverado dually w/19.5 rims.
1st gen, New Eras, s300, 366, DennyT, piston LP, Pacbrake, 60lbs. springs, ARP studs, Snow Perf. stage II, '97 DR IC, 4" stacks.
NV4500, 14 Bolt Locker & Dana 60 Posi w/3.73's
MrHorsepower
Postby finn188 » Sat Feb 28, 2009 4:26 pm
Im not sure where to get the numbers. I looked through the manual and all I found was:
Cummins 6B5.9 190hp, intercooled. the Allison is an AT 542.
finn188
Postby finn188 » Sat Feb 28, 2009 4:46 pm
MrHorsepower wrote:I have a '92 Gulfstream and it is rated at 190hp, intercooled. I will go look at the numbers it has on it tonight.
thanks
finn188
Postby PToombs » Sat Feb 28, 2009 5:19 pm
The numbers are in the edge of the timing cover. Climb in thru the wheel well and you can see 'em. ;)
Friend of mine has a MH with a factory cummins. He says it runs HOT! He did a turbo upgrade, and is in the process of putting in an I/C.
Before you get all excited and turning things up, run with guages so you can see where it's at. You might need a bigger I/C or something before injectors.
Postby sdstriper » Sat Feb 28, 2009 7:45 pm
You for sure want gauges, EGT and transmission for sure. That's a four speed without OD, correct? Get the gauges and turn up the pump some. Whats the intake like on that thing? How big of an exhaust is on it and how much clearance is there to go with a larger exhaust?
sdstriper
Postby finn188 » Sat Feb 28, 2009 9:09 pm
PToombs wrote:The numbers are in the edge of the timing cover. Climb in thru the wheel well and you can see 'em. ;)
Do you have a link to a good write up on gauge installation for the pyro, boost, and trans? Yes the trans is the non OD 4 speed. If I do find out if its running hot is water injection an option? I have a large water source anyways and could have it set up to run when pulling hills or whenever temps climb too high.... I think you are right about getting a baseline on what my current temps are.
finn188
Postby finn188 » Sat Feb 28, 2009 9:14 pm
sdstriper wrote:You for sure want gauges, EGT and transmission for sure. That's a four speed without OD, correct? Get the gauges and turn up the pump some. Whats the intake like on that thing? How big of an exhaust is on it and how much clearance is there to go with a larger exhaust?
Current exhaust looks like 3.5" with a huge muffler. Intake aprox. 5"? Yes there is lots of room for bigger exhaust.
finn188
