'91 Cummins wrote:If it is a '92 Cummins it will have an H1C turbo, which has no wastegate.
If you want to keep the EGT's low, I wouldn't suggest tweaking the pump. A set of injectors will give it a nice boost in power (DDP and New Era have very good reputations) and still be manageable in the EGT department.
You may also want to add a tranny temp gauge to your list. Don't want to cook that Ally.
sdstriper wrote:Was this a swapped in engine or is it factory? Can you get to the engine identification tag on the gearcase? If so, check the rated HP, same with the turbo, there is a tag on the turbo, ID the turbo and engine then report back.
Just because it is a 92' doesn't automatically mean it is built exactly the same as the Dodge CTD's. Unless it was a swapped in engine from a Dodge p/u...
MrHorsepower wrote:I have a '92 Gulfstream and it is rated at 190hp, intercooled. I will go look at the numbers it has on it tonight.
PToombs wrote:The numbers are in the edge of the timing cover. Climb in thru the wheel well and you can see 'em.![]()
Friend of mine has a MH with a factory cummins. He says it runs HOT! He did a turbo upgrade, and is in the process of putting in an I/C.
Before you get all excited and turning things up, run with guages so you can see where it's at. You might need a bigger I/C or something before injectors.
sdstriper wrote:You for sure want gauges, EGT and transmission for sure. That's a four speed without OD, correct? Get the gauges and turn up the pump some. Whats the intake like on that thing? How big of an exhaust is on it and how much clearance is there to go with a larger exhaust?
Users browsing this forum: No registered users and 68 guests
