1/2" fuel lines
1/2" fuel lines
Postby randyswelding » Thu Mar 26, 2009 7:01 pm
ok i got my new airdog with an-8 lines and fittings but the 90* -8 swivelx1/2" line ok my question is that 90* wont fit the adapter for the 1/2" lines cause of the fuel pump gets in the way of the nut! :x :mad: any one have the same dang problem and found a way to fix it?thanks guys a lot
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby randyswelding » Thu Mar 26, 2009 7:20 pm
i know i confused yall but any helpful tips?
randyswelding
Postby randyswelding » Thu Mar 26, 2009 8:38 pm
never mind i had a mad scientist moment :D and got-r-done i used the little 90* instead of the long one.the lil one went on the airdog for the tank vent and the big one was for the fuel pump so i switched them with the thratal(i cant spell)linkage off the pump and was able to get it all tight.but i did have to modify the bottom piece of the linkage by grinding the backwards hook and it all clears everything so im on to the next step makin a custom RW(randyswelding) mounting bracket tomarrow.
randyswelding
Postby gear jammer 91" » Sat Mar 28, 2009 9:06 am
Glad you got it figured out cause I'm still lost. :lol:
01 LB7
gear jammer 91"
Postby PToombs » Sat Mar 28, 2009 5:31 pm
Which way is up again? :?
Postby randyswelding » Sat Mar 28, 2009 5:51 pm
:D sorry guys that was the first murffys law insident! :x my new one was i broke off both the return and supply off the pump assembly(or so the dealer calls it,its the in tank portion)so now i got to drill 2 flippin holes one for the return and one for the supply tomarrow.i think i may try to reuse the pump assembly and do a big line up grade like talked about at DTR,but my new problem with that is that i got 1/2"line instead of the 3/8"line so i dont know if it will work or not,any suggestions i got regular reinforced fuel line is there a better way to do the supply line?work truck is down but i dont mind drivin my dads gutless 2nd gen but i need the power of mine back.man i love my first gens power! ill have pics soon i took them on my phone so it may be a while
randyswelding
Postby Ace » Sun Mar 29, 2009 7:23 am
Unles you are using some sort of aftermarket draw straw deal, as long as you have the pickup (pump assembly, or whatever you want to call it) out of the tank, make sure to open up the pickup hole. Or else your fancy new fuel system wil still be drawing through a tiny less than 5/16" hole in the pickup.
As far as the connectors on top go, you can find all the parts you need for that at just about any hardware store. Make sure to loctite/seal everything real good and use whatever size fittings you need for the line it's connecting. You'll spend a long time looking for and never finding the air leak if it ever comes loose inside the tank.
Ace
Postby randyswelding » Sun Mar 29, 2009 12:38 pm
Ok then where is a good place to get the draw straw tubin at?all I need is that 1/2"line cause I got all the fittings and what's the best way to seal both the return and supply since I broke both those plastic fittings on the pump assembly?
randyswelding
Postby DTanklage » Sun Mar 29, 2009 1:18 pm
i have a 1/2" id draw straw
new in box
comes with a neat billet alum pc, the grommet, a 90° -8 fitting and all
whats it worth to ya?
don
ps - what kind of hp worth of fuel you flowin w that ve? i would think 3/8 line would be plenty. no?
DTanklage
Postby randyswelding » Mon Mar 30, 2009 9:21 am
I got the straw made up yesterday like on the dtr but 1/2". Now I need another plug for the return so I won't have 2 broke fittings ill have 2 plugs and hp wise 1/2" is what the kit came with
randyswelding
Postby dpuckett » Mon Mar 30, 2009 9:22 am
Not to start "that" argument, but most of us could get by with a 3 or 3.5" exhaust, too. Bigger is better, even if not absolutely needed.
Postby DTanklage » Mon Mar 30, 2009 9:48 am
i guess
actally, i pretty much spend my weekends beating up on guys that think that way
bigger is better
if you run 1/2 supply line and a bypass reg what size is your return?
3/4?
lol
hope you mod the fitting that attaches this 1/2 line to your ve
don
DTanklage
Postby randyswelding » Mon Mar 30, 2009 6:47 pm
but look at what he drives a slowbutt 2nd gen :lol: i got it figured out a fresh can of cope and a shot or two of some jack and got-r-done
randyswelding
Postby DTanklage » Tue Mar 31, 2009 10:24 am
will pull 20k+ well over 100 mph
pull it 80 mph up anything
part throttle
you guys dont know what you are missing
to ea his own tho
i just use the truck to pull the race bike to the track
like God intented it to
DTanklage
Postby randyswelding » Tue Mar 31, 2009 1:17 pm
Oh ok:) ya mine aint very fast it weighs 12k though I bet it I took every thing off it would scare the sh t out of me.
randyswelding
Users browsing this forum: No registered users and 89 guests
