After market lift pump
Postby 2wd_sled_puller » Thu Apr 09, 2009 6:27 pm
I am thinking about putting a lift pump on my old first gen. The pump i have in mine is a PPE 160gph pump. A question i have is an electronic pump should be able to keep flow enough fuel to the ve pump correct? Anthor thing i hear alot about is the fuel lines on these rigs. Will i have to put bigger fuel lines on this truck. If so what size should i go with. Is a VE more about volume rather then pressure?
The HULK 1993 dodge cummins Afc work. Screw turned to runaway. Ht3b turbo looking for sticks
Piper 1997 chevy 2500 vortech 350 soon to be vortech 383
2wd_sled_puller
Postby JQmile » Thu Apr 09, 2009 7:00 pm
Nahhh, a 160gph pump will be fine for what you're doing. Stock is probably like 30gph, so this will be a big improvement. I'd keep the stock lines too, might want to bypass the filter though, and put a sump or draw tube in the tank. Factory tank has a pickup of like a 1/4 of an inch. I am sure others will chime in.
JQmile
Postby ford69557ci » Fri Apr 10, 2009 9:51 am
The 160 will do ok. I switched over to a prostar500 gph pump. I never had a fuel pressure drop problem though lol. If you plan on doing inectors and twins like your sig says. I would upgrade all of the lines, get rid of the stock filter setup, and go with 1/2 lines. Also you will need a return style regulator. I think the holley blue pumps are like 120 gph and I could drop the inlet pressure to 0 with one of those.
ford69557ci
Postby JQmile » Fri Apr 10, 2009 7:16 pm
Problem with the holleys is that they are rated 120gph, but only at 5-7psi, at free flow @ 14psi or whatever they are only like 75-80gph.
JQmile
Users browsing this forum: No registered users and 86 guests
