Injectors for 1993 Cummins 12V
Postby Bad93Cummins » Fri Apr 10, 2009 1:05 pm
Im thinking of getting these injectors for $300 they make about 120 HP and they're for 94-98 and getting sleaves to make them fit(just not sure how much or where to get sleaves) or get 4"straight pipe for $295 shipped.
Also will those injectors hurt my old motor? Has new injection pump and another pump had been replaced on the motor can't remember what is was called. Motor starts right up no problem and runs great just wanting alittle more power out of it, alittle smoke and not to hurt my mpg's to bad, getting about 16-18mpg.
Thanks
Bad93Cummins
Postby MudSlinger79 » Fri Apr 10, 2009 4:36 pm
You can not run 94-98 injectors on a 1st gen they have different pop pressure.
93 Ford, 1st Gen Cummins, 66/71/14 S-300, New Era 435 Sticks ,Pump Cranked, denny 2 fuel pin, afc MIA, 3200 spring. Sitting on 5 Ton Rockwells With 63" Rice And Canes. More To Come!!
MudSlinger79
Postby dpuckett » Fri Apr 10, 2009 4:53 pm
Pop pressure is the least of the worries. Bodies are different, and spray angles are not the same.
Unless you have a 4x4 club cab dually with an auto, you should be doing better than 16-18mpg, unless that's ALL in town. Mine will get 18hwy, but has significant wear in the pump H&R and cam plate.
Do a search on here, plenty of info on injectors. New Era and Coal Train are two that come to mind for 1stGen preformance injectors. Unless you use your new power all the time, it shouldnt hurt your mileage. May even improve it, depending on what shape your stockers are in now.
Daniel
Postby Bad93Cummins » Fri Apr 10, 2009 5:32 pm
So then ill probley get the 4" straight pipe and 3200 spring first then injectors then cold air intake.
The 4" straight pipe(3" off turbo, then 4" from firewall back with all new hangers an all) for $295 shipped and the spring is only $29.99 from http://dieseldawgs.com/product_info.php ... ts_id=1940
Then ill buy injectors then save up for the cold air intake( http://www.pdrdiesel.com/products/ASA_M ... 04-37.html )
then that should be about all the modding ill do to the ol cummins there and start saving up and get the tranny reubilt later on and maybe the motor later down the road.
BTW here's a set of injectors a feller off chuckstrucks.net said are real good.
http://dieseldawgs.com/product_info.php ... ts_id=1617
Bad93Cummins
Postby gear jammer 91" » Fri Apr 10, 2009 6:22 pm
check out http://www.stans-headers.com/ for exhaust, they make a real good 4" turbo back kit. On injectors, you need to make sure they are for a 91-93 cummins specifically, not for all years of 12valve.
01 LB7
gear jammer 91"
Postby Bad93Cummins » Fri Apr 10, 2009 7:03 pm
gear jammer 91" wrote:check out http://www.stans-headers.com/ for exhaust, they make a real good 4" turbo back kit. On injectors, you need to make sure they are for a 91-93 cummins specifically, not for all years of 12valve.
I thought about them but just can't afford them plus I think 4" straight pipe for less then $300 with all new hangers and exhuast is worth it.
10-4.
Thanks for all the help.
Bad93Cummins
Postby MudSlinger79 » Fri Apr 10, 2009 9:00 pm
Leave cumminsontherocks injectors alone they will not work on ur truck.
MudSlinger79
Postby Bad93Cummins » Fri Apr 10, 2009 9:48 pm
MudSlinger79 wrote:Leave cumminsontherocks injectors alone they will not work on ur truck.
I was lookin at smokin12value injectors he's selling, but I think im just going to order the 4" striaght pipe and the 3200 spring. Then injectors next, then cold air intake and fuel pin and call it quites.
Bad93Cummins
Postby beerboy81 » Fri Apr 10, 2009 10:25 pm
i got my 3200 spring just for $19.99 ck it out.. puredieselpower.com
ofc, that doesn't include the shipping..
and im still waiting on instructions on how to install it lol :oops:
Jake
'93 W250 LE '92 CTD/IC GETRAG 5sp. 4x4 4" lift 33x15.50x16 TSL/SX Super Swampers, Pumped up, ASA Mods, cooler tubz, 5" stacks.. 366 hiding in the glove box
beerboy81
Postby peobryant » Fri Apr 10, 2009 10:37 pm
beerboy81 wrote:i got my 3200 spring just for $19.99 ck it out.. puredieselpower.com
http://dens-site.net/Dodge_CTD/Governor ... index.html
Best instructions I have seen...
Postby 2wd_sled_puller » Sat Apr 11, 2009 9:43 pm
Bad 93 where did u find that kinda exhaust i need 5 inch turbo back
The HULK 1993 dodge cummins Afc work. Screw turned to runaway. Ht3b turbo looking for sticks
Piper 1997 chevy 2500 vortech 350 soon to be vortech 383
2wd_sled_puller
Postby LOGANSTANFORTH » Sun Apr 12, 2009 7:20 am
5 inch wont fit on a 1st gen without doing some serious work to the firewall.......
get Stan's 4 inch downpipe and build a 5 inch kit for your truck.......
THEY PUT THEM ON A PLANE TO SOME STRANGE AND FOREIGN LAND, THEY SAID GOODBYE TO MOM AND DAD AND HELLO TO UNCLE SAM, THEY NEVER THOUGHT THE DAY WOULD COME WHEN THEY MIGHT HAVE TO KILL A MAN, THEY DID NOT SLEEP A WINK THAT NIGHT BUT THEY WON FOR UNCLE SAM
LOGANSTANFORTH
Postby RSWORDS » Sun Apr 12, 2009 9:42 am
Bad93Cummins wrote:So then ill probley get the 4" straight pipe and 3200 spring first then injectors then cold air intake.
I'm running that exhaust and I like it alot.
And I'm not sure I would listen to anyone off Chuckstrucks for any kinda logical advice. :lol:
RSWORDS
Postby SChandler » Mon Apr 13, 2009 9:45 am
Bad93, the injectors that you linked to are an overpriced set of POD's. You can buy them new for less than $400 or used for $300-ish. Try PDR or Pure Diesel Power for the injectors.[/url]
SChandler
Postby beerboy81 » Mon Apr 13, 2009 10:25 am
thanks 91! better safe, than sorry... :roll:
Jake
beerboy81
Users browsing this forum: No registered users and 83 guests
