Hey guys,
I have been researching upgrading my fuel system, and the main concern I have is the pickup, pretty sure I will go with either a draw straw or a bulkhead fitting/sump in the bottom of the tank. I am curious how much these affect fuel pickup when the tank is run low, which I seldom run mine below 1/4 tank anyway. Using a draw straw or a bulkhead fitting either one is cost effective, I just want it to work good, I also found this over on CompD; pretty sweet, but kinda $$$
http://www.competitiondiesel.com/forums/showthread.php?t=48772&highlight=draw+straw
I recall seeing a thread that someone drilled out the passages in the head for the fuel filter, I cannot find it again?? Not sure if I saw it here or another forum?
Thanks, Steven
