Fuel pickup upgrades
Postby CAROLINA CUMMINS » Sat Apr 11, 2009 8:00 pm
Hey guys,
I have been researching upgrading my fuel system, and the main concern I have is the pickup, pretty sure I will go with either a draw straw or a bulkhead fitting/sump in the bottom of the tank. I am curious how much these affect fuel pickup when the tank is run low, which I seldom run mine below 1/4 tank anyway. Using a draw straw or a bulkhead fitting either one is cost effective, I just want it to work good, I also found this over on CompD; pretty sweet, but kinda $$$
http://www.competitiondiesel.com/forums/showthread.php?t=48772&highlight=draw+straw
I recall seeing a thread that someone drilled out the passages in the head for the fuel filter, I cannot find it again?? Not sure if I saw it here or another forum?
Thanks, Steven
91 W250 5spd 3.54 SBC 13" ConFE BHAF 5"Mitres Di-Pricol EGT/Boost 16cm 366 Mag-Hytec Borgeson 285/75-16's 233/568 TiM '04 257,000mi
CAROLINA CUMMINS
Postby Ace » Sat Apr 11, 2009 11:15 pm
I like that tank sump idea. That's what I'll do if I ever need more fuel.
The pickup and filter are the big restrictions. You can mod that stuff for minimal cost and get enough fuel for some pretty serious HP with a piston pump and bigger lines.
Postby skilletky » Sun Apr 12, 2009 12:36 am
i got a pick up tube kit when i got my FASS that i am not going to need if you are interested. i was going to put it in my truck, but i got other things to do now, plus, my fuel preessure stays a stedy 16psi no matter how heavy the foot gets.
skilletky
Postby CAROLINA CUMMINS » Fri Apr 17, 2009 1:16 am
PM'd ya on the pickup tube skillet. thanks
Another question, if I install a inline fuel filter/strainer does it have to be diesel rated, one rated for gasoline and alcohol should work right? Most of the decent ones(as in affordable) are -8an in/out 40-100 microns, around 100-150 gph. For some reason the diesel rated ones are $100 + :shock:
Thanks, Steven
CAROLINA CUMMINS
Postby Ace » Fri Apr 17, 2009 2:08 am
If you are talking about bypassing or eliminating the stock filter then yes, it should be for diesel with a water seperator, rated for 10um max. Any water and junk bigger than that getting through the filter will wipe out the VE and injectors pretty quick.
Postby CAROLINA CUMMINS » Fri Apr 17, 2009 6:37 am
This is just a filter for catching the big stuff before the LP
CAROLINA CUMMINS
