HX35W
HX35W
Postby Oddfire » Fri Apr 17, 2009 2:05 pm
Where is a good place to run the waist gate actuator hose from? :roll:
:lol: [/b]
Oddfire
Postby gear jammer 91" » Fri Apr 17, 2009 4:29 pm
i though those turbo's had a fitting on the compressor housing? If not I think there should be a flat round spot on the compressor housing that could be drilled and tapped to get a boost signal. If you don't want to do that you tap into any of the boost tubes between the turbo and the intake, or at the fitting in the head.
01 LB7
gear jammer 91"
Postby Oddfire » Sat Apr 18, 2009 8:24 pm
This one wasn't tapped in the boss on the housing. I didn't feel like drilling in the nice smooth housing, so I tapped into the boss on the top of the cast elbow clamped to the compressor outlet. :lol:
Man this thing sings under boost!!!!!!!!!!!!!!!!!! ;-)
Oddfire
Postby DTanklage » Mon May 04, 2009 8:28 pm
itsa great little turbo isnt it?
on a 325 hp set up they really make the truck 'feel' fast
i think they are too restrictive for too much more than that but man do they make the truck pull at that level
we took one off of what was a pretty quick p-pump truck, installed a s300, and it turned into a dog
then we gave it some fuel
really dont think you can beat the hx at 300 hp or so
wonder how one would do at 425 if you added an external waste gate?????
DTanklage
Postby Oddfire » Tue May 05, 2009 4:56 am
:jumpsmile:
Oddfire
Users browsing this forum: No registered users and 81 guests
