Aeromotive A-1000 fuel system
Postby soggy » Tue May 12, 2009 10:06 pm
I'm going to start my aeromotive a-1000 fuel system as soon as parts get here. I got the 13204 regulator also. I've read up on it as much as i can but still want see what you guys running it think. What size lines? Where do you mount the pump? Close to the tank and below it? How about the regulator? My plan is to run 5/8 from tank to pump, 1/2 in from pump to regulator, and 3/8 from reg to VE per Bgilberts setup. That's about all i have figured out so let me know what I'm missing and what I'm wrong about. By the way i know I dont need this much pump for the setup I have but my stock pump is on the way out and I'm planning on going big as money allows. I'm planning on around 4-500 horse for a daily driver/ drag racer. Not trying to be too original or break any records, just want to follow the proven path to a fast 1st gen. Thanks in advance.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby soggy » Tue May 12, 2009 10:13 pm
Also, can i run just the 10 micron Aeromotive inline filter with it? Or do i need something bigger?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby KTA » Tue May 12, 2009 10:32 pm
I run the Aeromotive filter before my pump and then run a standard big truck fuel filter after the regulator before the injection pump.
Postby soggy » Wed May 13, 2009 11:43 am
Thanks KTA, anyone else have info?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby seeker1056 » Wed May 13, 2009 12:25 pm
I'm usin #12 line from tank to a moroso inline filter, then #12 from filter to pump, #10 line from pump to K-wopper fuel and water filters, #8 line to the regulator, 6 return, #6 to the IP,
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby soggy » Wed May 13, 2009 12:40 pm
Thanks seeker, where could i find a filter head and filter for after the reg? 10 micron enough or do i need a 2 micron? KTA, why do you run your filter after the regulator?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby soggy » Wed May 13, 2009 9:49 pm
What about this setup from glacier diesel? Would it flow enough?
http://www.glacierdieselpower.com/product.aspx?pf_id=FF5320-UK
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby soggy » Sat May 16, 2009 5:52 pm
How have you guys been wiring your electric pumps?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby GO OVRIT » Sun May 17, 2009 4:15 am
soggy wrote:How have you guys been wiring your electric pumps?
I tapped in to the fuel shut off wire to turn a relay on for the pump.
GO OVRIT
Postby soggy » Wed May 20, 2009 9:07 pm
I got it finished finally, not going to be a real writeup but I'll try to give a little info.
I took the bed off to do it and I would recommend doing that if you're doing a fuel system. If you have a nice John Deere loader tractor around that is:cool:.
I ran a 5/8 line from the Hellman sump to the A-1000.
I also put the Aeromotive 100 micron inline filter just before the pump and then ran a 1/2 in line from the pump to the filter, and continued with a 1/2 in line to the regulator.
The regulator is an Aeromotive 13204, adjustable from 3-15psi and capable of boost referencing. I'm going to hold off on the boost referencing until I get a built pump and big sticks. From the regulator I ran a 3/8 in line to the VE and a 1/2 return line back to the tank. Fatty built me a mounting bracket.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby soggy » Wed May 20, 2009 9:15 pm
Pics of the regulator.
For the return I used a fitting that was left over from my brothers Airdog kit. It was for the drawstraw but he went with a sump also.
Although I didn't really do this mod to get me more power( it was more to be able to support lots of power) I did notice it is way stronger on the top end. Also a little more boost and higher egts.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby SChandler » Thu May 28, 2009 5:48 pm
Nice setup, that should be able to support lots of HP. Looks like a clean install. What filter head did you end up using? It has 1/2" fittings, right?
SChandler
Postby soggy » Thu May 28, 2009 9:36 pm
I'm not sure, I went to the local napa and told them i needed a big filter and the head to go with it, yes they are 1/2 in fittings.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Users browsing this forum: No registered users and 78 guests
