Giles@PerformanceDiesel wrote:Hey guys
Giles here, it's a pleasure to be on this forum and hope we can all
work together to make some great HP/Torque.
Ken has said that his last pump we built for him has the VW governor
setup, that's not correct. it has the "354" 4200 rpm gov spring.
yes the 14mm head did seize up on the bench because a part of the
broken cam plate got in. i managed to fix it very carefully with a fine
hone stone by hand.
so he's got the 14mm head and 320cc's of fuel which is 3x stock fuel
and still just over stock fuel at 0 boost. like he said 2 turns of fuel
left to play with on the dyno or truck pull days.
look forward to dealing with more of you on a personal basis
Giles
www.performancediesel.ca
905-940-2266
