HX55?
HX55?
Postby Bad93Cummins » Tue May 19, 2009 12:04 pm
Bad93Cummins
Postby Begle1 » Tue May 19, 2009 1:39 pm
Yeah, they're a very common turbocharger.
A tad bit smaller than the HT3B which is the benchmark for twins setups; it would work below an HX35/ HX40/ HY35/ S300 just fine for a smaller set-up.
Postby Bad93Cummins » Tue May 19, 2009 6:25 pm
could you run just this set-up, not looking at doing twin's.
Bad93Cummins
Postby peobryant » Tue May 19, 2009 6:39 pm
You could run it, but I wouldn't recommend it.
Also, I haven't looked at the Ebay page, but I would be willing to bet is is a cheap knock off of a Holset turbo. A lot of people do that on Ebay.
Postby RSWORDS » Tue May 19, 2009 6:42 pm
Bad93Cummins wrote:could you run just this set-up, not looking at doing twin's.
You would have a very hard time spooling it.
RSWORDS
Postby Begle1 » Tue May 19, 2009 7:52 pm
4000 RPM governor spring and a converter with a 3000 RPM stall, plus a 300 HP shot of nitrous should get it lit. :D
Users browsing this forum: No registered users and 83 guests
