My new fuel system
My new fuel system
Postby ZSkibo » Thu Sep 24, 2009 7:02 pm
Thought I'd share a little...It consists of a Vulcan I drawstraw (1/2") to 1/2" lines front to back. Fed by a high pressure 2nd gen piston pump and regulated by a boost-referenced bypass regulator. I have 15psi from idle to WOT and the boost-reference keeps it there all the way through. What did I gain? It's not a seat of "the pants" performance increase but she pulls strong all the way through now from off-idle to max rpm (3200) and there is no more of that running lean feeling I had in the higher RPMs. Overall, I'm glad I did it this way as I kept my mechanical pump (no electrics to fail), have the boost reference, and I know my VE is getting fed and cooled.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby Ace » Thu Sep 24, 2009 7:09 pm
That'll work. 8)
Ace
Postby Cummins Junkie » Fri Sep 25, 2009 8:42 am
What brand of regulator did you use, would you happen to have the part number?
1991.5 W250 NV4500 Swap, Ats Manifold, Dual 5" Stacks, Autometer Gauges,P-Pump Swap, KDP Beat Into Submission, 4k GSK, 0 Plate, 191 DVs, P/S Intercooler, 3" Stainless Cooler Tubez, BHAF, Super Hx40, 370s
Cummins Junkie
Postby SChandler » Fri Sep 25, 2009 8:57 am
Good work. :salut: Should be a 400hp fuel supply for sure. Which Draw Straw did you use? Have you run the tank down low (less than 1/4 tank) to see how it does? It seems like people have problems with low fuel levels. I saw that Vulcan has a new Draw Straw (the V), that is supposed to not have the low fuel level issues, but it's meant to be used with the 3rd gen tank setup.
SChandler
Postby Richie O » Fri Sep 25, 2009 9:12 am
I think I would do a helman sump if I ever need more fuel.
Postby RSWORDS » Fri Sep 25, 2009 1:20 pm
Looks like the mallory regulator i used. $100 and trouble free so far!
RSWORDS
Postby seeker1056 » Fri Sep 25, 2009 2:52 pm
you pic shows no boost line to the afc anymore - how do you get the fuel pin to work?
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Richie O » Fri Sep 25, 2009 3:41 pm
His sig says AFC out. :D
AF-what? Ha ha...
Postby ZSkibo » Sat Sep 26, 2009 6:30 pm
Oh yeah that....um, it's hanging from my rearview in case I ever want to put it back in. Trouble is, I can't imagine why I'd want to... 8)
ZSkibo
Postby ahale2772 » Wed Sep 30, 2009 6:45 pm
just bought the piston pump for my truck today being in college i couldent go myself so my father went because he needed freeze plugs for his 24 valve .... after repedely telling him to ask for the 15 psi pump and giving him all sorts of part numbers he comes back with the 30 psi pump ...i guess im gona do the same thing and use a pressure regulator think one without a boost reference will work ok?
Yep
Postby ZSkibo » Sun Oct 04, 2009 7:27 am
The boost reference is not a requirement. It just maintains your preset pressure under heavier loads. You'll probably never notice the difference.
ZSkibo
Postby ahale2772 » Sun Oct 04, 2009 5:06 pm
ok thanks , i went to install the pump today and i found 2 things the angle of the contact pad on the piston pump looked very low lilke the rod was pointing to the bottom of the cam... i was wondering if that is correct and what did you do with the insulation around the breather pipe just above the casting for the pump? ive heard of people cutting it out is that what u did?
Postby ahale2772 » Wed Oct 07, 2009 7:53 am
by the way ZSkibo i just bought the same regulator as u off summit how do u like yours? any problems im going to run the same system as u minus the draw straw
Re: Yep
Postby Ace » Wed Oct 07, 2009 8:45 am
ZSkibo wrote:The boost reference is not a requirement. It just maintains your preset pressure under heavier loads.
Regulators aside, the "best" way to maintain fuel pressure is simply install adequate plumbing, i.e. at least 3/8" supply I.D. from the pickup all the way to the injection pump. Do that, and a 15psi piston pump will maintain 15psi at WOT under load up to some abnormally high flowing injector/VE combo.
Ace
Postby ahale2772 » Wed Oct 07, 2009 8:51 am
yeah i have 3/8 parker pushlock running the length of my truck with a 3/8 return also stock pick up/ return in my tank tho (think i should change that?) im thinking about making stainless hard lines this winter as well as making my brakelines out of this nickle/stainless stuff ive been using lately
Users browsing this forum: No registered users and 63 guests
