idle adjustment
idle adjustment
Postby mprmn08 » Wed Oct 21, 2009 3:55 pm
How the heck do you loosen and turn down the idle with it so dang tight in there. i started turnin up the smoke screw and now i cannot get the nut loose to turn my idle back down. im gettin very frusterated. please help
mprmn08
Postby PToombs » Wed Oct 21, 2009 5:41 pm
I used to pull the fuel return line and then pop it loose with a 13mm deep 1/4 drive socket. Then I turned the screw with screwdriver bit in a socket, same drive size.
Postby Begle1 » Wed Oct 21, 2009 6:39 pm
Screwdriver and hammer to tap the jam nut loose, wedge a 1/4" boxend over the threads to turn the Allthread piece.
Postby dpuckett » Wed Oct 21, 2009 6:52 pm
I used Begle's method, with the exception of using a small screwdriver to turn the all-thread. After about 6 adjustments, the jambnut looks like it went through a feed mill grinder.
Dan
Postby Begle1 » Wed Oct 21, 2009 6:54 pm
It looks bad after 6 adjustments, but it works for 12 adjustements.
Who doesn't have the pump off at least once every 12 adjustments? :lol:
Postby slowdiesel » Wed Oct 21, 2009 10:21 pm
I just use a dremmel.
1984 D100 Ve-Twins.
Special Thanks Mayer Farm Equipment
slowdiesel
Re: idle adjustment
Postby ashbyota92 » Thu Oct 22, 2009 2:47 am
mprmn08 wrote:How the heck do you loosen and turn down the idle with it so dang tight in there. i started turnin up the smoke screw and now i cannot get the nut loose to turn my idle back down. im gettin very frusterated. please help
I had a problem with the jamb nut on mine(froze up solid after 1/2 turn).
I put another jamb nut on the other end of the screw.
6x1.00 (jamb nut, specifically thinner!) I bought from the local hardware
store. It's easier to adjust for me, and I have a reference point for stock settings,
from the idle adjustment screw jamb nut frozen!
I lost track of the the fuel screw settings along time ago!
Small cold chisel & hammer. Nice and easy!
'92 W250, 6" lift 35x12.5 BFG's, 14cm housing, pillar mount boost & pyro. DDP stg2 injectors, Denny T fuel pin, 366 spring.
ashbyota92
Postby Ace » Thu Oct 22, 2009 6:30 am
I'm going to replace that allthread with something you can actually get a tool on one of these days....
Ace
Postby 1STGENFARMBOY » Thu Oct 22, 2009 6:47 am
I did the samething as Dan and my nut looks bad to, but its alot easer than trying to get a socket on it. ;)
Postby IowaCummins » Thu Oct 22, 2009 2:19 pm
Ace wrote:I'm going to replace that allthread with something you can actually get a tool on one of these days....
on my fuel screw and my low idle screw iwedged on a 7/16 nut on the all thread part or maybe smaller not sure then welded it on adn now i have fairly easy adjustments
IowaCummins
Postby mprmn08 » Thu Oct 22, 2009 4:50 pm
thanks for all the advice guys. i got it today. i did the hammer and "chisel" almost got frusterated and started swingin hard when i couldnt get loose after bout 5 min but then it came. i've still got some more i can go in with the fuel screw but ive been gettin home late all week from work so it'll have to do 1 1/2 in for now.
chris
mprmn08
Users browsing this forum: No registered users and 66 guests
