Power Upgrades
Power Upgrades
Postby carlosrivero71 » Thu Oct 22, 2009 3:33 pm
Apologies for posting to multiple forums, but as they say "knowledge is power" and power is why we're all here.
I have a 91.5 intercooled CTD automatic in a 93 chevy 1500. Current mods: MasterPower turbo (don't know the sizes), BHAF, open 4" exhaust (straight back),
and ground fuel pin, starwheel turned down all the way. Lots of smoke once I hit the go pedal. Some go, but not much - EGTs goin' up real fast tho.
Only get about 8psi of boost. Lot's of white smoke at idle.
Anyway, recently resurrected the project after a 3 year hiatus (translated: divorce and custody battle) and want to give her (the truck) some Christmas presents.
This is what I'm thinking:
KDP kit
3200 Spring
Fuel Pin (Denny T is looking really good right now) - any suggestions
Water/Methanol Injection (Snow Performance???)
Propane Injection - suggestions/advice???
Replumb the air intake and intercooler pipes (it's a mess right now)
Any comments or suggestions?
93 Chevy 1500 Regular Cab Short Bed - 91.5 Intercooled CTD Automatic MasterPower turbo, BHAF, 4" straight-back exhaust, No AFC spring, turned starwheel all the way down, full fuel screw adjusted and rotated fuel pin
carlosrivero71
Postby ahale2772 » Thu Oct 22, 2009 3:54 pm
something in ur turbo is junk if ur making 8psi of boost only...i reccoment the denny t pin it is the balls
Postby Richie O » Thu Oct 22, 2009 3:57 pm
High egt's and low boost sounds like a boost leak to me. Any how, the master turbo is not the greatest. I thought about buying one but asked around and changed my mind.
Postby PToombs » Thu Oct 22, 2009 5:10 pm
Better figure out what is wrong before you put any more fuel to it. Check the IC and tubes real close for leaks.
Have you done anything with the timing? White smoke, high EGT's, could be the timing is retarded some.
Postby ford69557ci » Fri Oct 23, 2009 10:00 am
Master power turbos are kinda crap. I normally wouldnt say this but a hx40 is better lol. 8psi will cause some high egt and tons of smoke so I would say ya got a serious boost leak
ford69557ci
Postby carlosrivero71 » Mon Oct 26, 2009 9:47 am
Thanks guys. I figured the turbo was crap, not to mention the quality craftsmanship of the work done on the air plumbing and exhaust. I'll post some pics so you guys can take a look.
carlosrivero71
Users browsing this forum: No registered users and 65 guests
