Twins or single
Twins or single
Postby jmono » Thu Oct 29, 2009 6:28 pm
I'm not really familiar with these injection pumps. How would a decent sized charger spool? I was thinkin twins with an hx35/ht3b, but in the back of my head I have always wanted a big single. Like a silver bullet, 66mm charger with a 12 or 13 exhaust. Would it be very tolerable or do you think it would be laggy? Could I spool it with a 12mm pump with a set of 6x.016s or 6x.018s fed by a airdog or something similar or would I have to add a 14mm head and 4mm cam plate? Another quick question, at what PSI do you guys recommend o-rings? 50lbs?
TIA Jake
1990 Dodge W250 R/C 4x4, Non I/C Cummins, 727 auto, autometer gauges, ground fuel pin, 366 spring, maxed out ve, straight pipe, 2ish" lift, and 35" BFG M/T's on 16.5" rims.
jmono
Postby peobryant » Fri Oct 30, 2009 5:06 am
Twins will spool way faster than a big single. A 66mm charger would probably be very laggy with a VE. I'm sure with tuning you could get rid of some lag, but it would be a pain to daily drive.
Twins
Postby Bigfury » Fri Oct 30, 2009 9:35 am
Don't be scared,go with twins.He!! anybody can install a single on one of these motors.The real challenge is to get a pair of them to work together. :grrr:
'90 non I/C,Getrag,4" straight ex.,500,000,wanting bigger- injectors,turbo.In progress is powerjoke I/C,BHAF
Bigfury
