boost gauge install
boost gauge install
Postby Remps » Sun Nov 15, 2009 9:02 pm
Anyone know where to get a tapped bolt for the intake manifold?I still haven't put my 100 lb boost gauge in yet,cause I don't want to drill a hole in the intake.Any other options?
Postby Richie O » Sun Nov 15, 2009 9:06 pm
I got mine from geno's. It came with my gauge.
Postby PToombs » Mon Nov 16, 2009 6:51 pm
All you need is a 1/8" pipe adapter. There are 2 holes in the side of the intake with plugs in them. One is near the throttle cable mounting plate, and the other is forward a little.
Postby Richie O » Mon Nov 16, 2009 7:08 pm
Pete, on a non cooled truck you have to drill the throttle brackets to get to the plug you used on your rig. On my 89 it was just easier to use a intake bolt machined for 1/8th inch pipe.
Postby ahale2772 » Tue Nov 17, 2009 7:16 am
i had to drill my throttle bracket out not to tricky but i almost nicked one of my injector lines....and it was tricky to get a fitting threaded in
Postby Tacoclaw » Tue Nov 17, 2009 10:18 am
I got the same thing as Ritchie from Genos Garage.
http://www.genosgarage.com/prodinfo.asp ... LT-ADAPTER
Pretty handy if you ask me. :)
Postby PToombs » Tue Nov 17, 2009 6:20 pm
Got ya Rich! You non-IC guys have it rough, don't cha? :lol:
Postby Richie O » Tue Nov 17, 2009 6:33 pm
Yup. :D
Postby Remps » Thu Dec 10, 2009 9:31 pm
Finally got the darn thing installed.Minus 40 Celcius here with windchill,and finally got access to a shop for a day and fixed a bunch of stuff.Drilled a 3/4" hole in the bracket,and the fitting that came with the gauge fit.Transmission and roads too slippery to get over 22 psi so far. :D
