tank pickup....How?
tank pickup....How?
Postby bigred cummins » Tue Nov 24, 2009 12:05 am
How do I upgrade the intank pickup tube in my truck? Who here has done it? There used to be a writeup on DTR but I think their website is down.
bigred cummins
Postby BC847 » Tue Nov 24, 2009 5:51 am
Postby bigred cummins » Tue Nov 24, 2009 6:43 am
link no worky. It says "Failure To Connect To Web Serve," Its been like that for probably 4 months when I try to go there.
bigred cummins
Postby dragrdan » Tue Nov 24, 2009 7:28 am
link works for me
93 W250 5spd, Comp 275, HE351CW, 5X18, IP turned up, 3200 spring, BHAF.
dragrdan
Postby Ace » Tue Nov 24, 2009 9:00 am
Clear your browser cache.
Ace
Postby bigred cummins » Tue Nov 24, 2009 2:43 pm
the hoobity-what? How? I am completely computer illeterate. They make me want to smash stuff with a hammer.
bigred cummins
Postby bigred cummins » Tue Nov 24, 2009 2:44 pm
nvm. I found it.
bigred cummins
Postby bigred cummins » Tue Nov 24, 2009 2:52 pm
and it still doesnt work. I went to "Tools" Then "Clear Private Data" and checked all the boxes, and pressed OK and it still doesnt come up. It says
Failure To Connect To Web Server
bigred cummins
Postby Ace » Tue Nov 24, 2009 3:07 pm
Forget the link then, just go to dieseltruckresource.com, and search for 151190.
Ace
Postby bigred cummins » Tue Nov 24, 2009 3:12 pm
I have tried that. I have been getting the same message from their site for like 4 months now. I havent even been able to get on. From this computer, or my laptop. I thought their site was gone honestly.
bigred cummins
Pickup upgrade
Postby ZSkibo » Wed Nov 25, 2009 3:56 pm
Is very easy. Get a drawstraw from Vulcan. It utilizes your factory tank grommet, gives you 1/2" lines and a pickup. Very easy to install. They also carry all the fittings if you want to go 1/2" all the way to the pump inlet. There's another post on the board titled fuel system. Read it.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Users browsing this forum: No registered users and 66 guests
