I want 350 to the wheels . can i do it?
Postby Lucas » Sun Dec 06, 2009 1:07 pm
they dont list the ats manifold for the first gen guys.iam asuming a 94-98 12v will fit?
is it woth it? anyone run it ...was thinking it may make my turbo swap easier.and give me room for twins in the future :?:
http://www.atsdiesel.com/ats2/productde ... _Manifolds
was going to also add
snow- water meth
exaust manifold- ATS
banks -intake manifold if it will fit without cutting the hood too much
already have a 99 powerstroke intercooler in the garage and a 06 take off turbo (he351) on the shelf .-still researching to put it together
have 6 weeks off in jan lookin to play with it then
is 350 is a little un-realistic?
Lucas
They are all drop-in
Postby ZSkibo » Sun Dec 06, 2009 1:15 pm
Everything will fit fine, shouldn't have to cut your hood (???). 375HP to the wheels is totally obtainable.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby bgilbert » Sun Dec 06, 2009 1:45 pm
I would skip the ats exhaust manifold unless your stock manifold is shrunk and about to break an ear off. Also don't waste your money on any banks product for a 1st gen.
Spend the money on injectors or a turbo before any of the above.
Bill Gilbert
bgilbert
Postby TWorline » Sun Dec 06, 2009 1:50 pm
350 HP is not that hard to come up with, take a look at my sig.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Richie O » Sun Dec 06, 2009 2:14 pm
TWorline wrote:350 HP is not that hard to come up with, take a look at my sig.
I think its the borgeson shaft that put you over the top. :D
Postby TWorline » Sun Dec 06, 2009 5:46 pm
You know I never really thought about it but, I'll bet you're right! ;-)
Tim Worline
TWorline
Postby 1STGENFARMBOY » Sun Dec 06, 2009 8:04 pm
Sometimes your steering gets alittle wobbly when your on the rollers, :lol:
Postby Redneckintraining » Sun Dec 06, 2009 8:19 pm
What no yellow or red engine parts?Those are worth 100 HP/200 lbs tq for every square inch... :lol:
Redneckintraining
Postby Lucas » Tue Dec 08, 2009 12:02 am
new idea.......iam not going to mess with it anymore ...calculated my milage :shock: 11mpg now ...what the hell is going on??
and thats driving eith my foot out of it!!!
1992 dodge 350 ic 4x4 dually -auto -410 gears
starwheel bottomed out -40 hp nozzles
pump at runaway.PDR fuel pin.
K+N filter with intake box piped with cold air
Lucas
Postby Diesel Dawg » Tue Dec 08, 2009 2:15 am
How does the truck run? You should be at least 15-16 mpg or more!!!!!! How is your air filter? fuel filter? is it missing or low on power? May try fuel cond. or could be injectors worn.
Diesel Dawg
Postby TWorline » Tue Dec 08, 2009 7:08 pm
Lucas wrote:new idea.......iam not going to mess with it anymore ...calculated my milage :shock: 11mpg now ...what the hell is going on??
You have a 4X4 dually with an auto and 410 gears, that is what is going on. Lots of weight, high rolling resistance and a higher operating RPM range= low MPG.
Tim Worline
TWorline
Postby ahale2772 » Tue Dec 08, 2009 7:15 pm
plus our trucks have the aerodynamic qualitys of a brick wall
Postby SNOOT » Tue Dec 08, 2009 8:28 pm
I can get 16-17 on the freeway and 12-14 around town and make 355HP in current form.
What converter is in your truck ... Get that stock thing out of there if you have one...
http://www.youtube.com/watch?v=Bi21zyQCa9s
1993 W350
SNOOT
Postby Lucas » Tue Dec 08, 2009 10:30 pm
stock convertor
truck runs great and the injectors had the nozzles doner and tested less than 9000miles ago.
iam thinking the pump is turned in to much... i get slight haze at idle and she smokes like a train when my foots into it.
410 gears and barbie doll wheels doesnt help either
filter is new
and I always run standadyne
Lucas
Postby peobryant » Wed Dec 09, 2009 12:37 am
Get rid of that stock converter. Give Dave Goerend a call, he'll set you up.
