injector ?
injector ?
Postby new dad » Fri Jan 01, 2010 11:30 am
my injectors in my 98 are ddp90's. does anybody know the #of holes and the size of holes? thanks in advance for the info.
98 3500, 5sp, dpp 90's, 10 plate, 4k springs, sb fe. totalled
90 d250 727, stock for now, coming soon: trans swap from a '95 2nd gen, 366 spring, m&h m5, custom crossover plumbed for a little w/m and n2o
new dad
Postby RSWORDS » Fri Jan 01, 2010 3:42 pm
I think they are 5 Holes but not sure of the size.
RSWORDS
Postby ccoxva » Fri Jan 01, 2010 7:00 pm
They are 5x10's or 12's.
1991 N/I 250
1996 Dodge 3500 Ex. Cab Dually 19.5's
ccoxva
Postby new dad » Fri Jan 01, 2010 9:28 pm
370's are considered a 60 hp injector in a second gen. from the injector info chart it says that 370's are 5x.012. so a 90hp injector would have to be bigger right?
new dad
Postby lectro_static » Fri Jan 01, 2010 10:35 pm
I think, and Im sure if Im wrong I will be corrected, you are trying to compare apples and oranges. IF I understand correctly the HP rating is for that gen of truck so while a 60hp injector may be 60hp for a 2nd gen the same size and number of holes may be 100hp on a 1st gen. While the numbers are made up you get the idea. Also if you are looking at using your injectors out of your 98 into your 90 they wont work the pop pressure is different, the nozzles MAY work but Im not sure if the spray angle is the same
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby new dad » Sat Jan 02, 2010 12:24 am
how much power can ya get out of the stock sticks? i wanna see some #'s lol
new dad
Postby burnt_servo » Sat Jan 02, 2010 6:16 am
lectro_static wrote:I think, and Im sure if Im wrong I will be corrected, you are trying to compare apples and oranges. IF I understand correctly the HP rating is for that gen of truck so while a 60hp injector may be 60hp for a 2nd gen the same size and number of holes may be 100hp on a 1st gen. While the numbers are made up you get the idea. Also if you are looking at using your injectors out of your 98 into your 90 they wont work the pop pressure is different, the nozzles MAY work but Im not sure if the spray angle is the same
i think it's the other way ,
if it's a " 60 hp 2nd gen " injector , the same size injector will make less hp on a first gen due to the lower injector pop pressure .
'93 w250 .... stock ...
burnt_servo
Postby cedardiesel » Sun Jan 03, 2010 9:43 am
Anyways if you looking to use the injectors out of the 98 you can but only the tips cause the bodies are slightly different from p-pump to ve injectors
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Re: injector ?
Postby Smokem1 » Mon Jan 04, 2010 8:02 am
new dad wrote:my injectors in my 98 are ddp90's. does anybody know the #of holes and the size of holes? thanks in advance for the info.
5x0.012" 155°
Smokem1
