lectro_static wrote:I think, and Im sure if Im wrong I will be corrected, you are trying to compare apples and oranges. IF I understand correctly the HP rating is for that gen of truck so while a 60hp injector may be 60hp for a 2nd gen the same size and number of holes may be 100hp on a 1st gen. While the numbers are made up you get the idea. Also if you are looking at using your injectors out of your 98 into your 90 they wont work the pop pressure is different, the nozzles MAY work but Im not sure if the spray angle is the same
new dad wrote:my injectors in my 98 are ddp90's. does anybody know the #of holes and the size of holes? thanks in advance for the info.
