Fuel mileage help!!!tinker with pump need answers asap
Postby cummins4life875 » Sun Jan 10, 2010 9:15 am
1992 w250 ext cab 5 speed 4x4 4.10 gears
80 hp injectors
bully dog fuel pin
13mpg
i want more mpg dont care about power....
what can i do to tweak the pump
fuel screw how many turns in or out
idle?
afc?
cummins4life875
Postby BC847 » Sun Jan 10, 2010 9:43 am
- Put the stock/OEM fuel pin back in.
- Install known high quality injectors in (like the PDR 190 injectors or the like that provide better atomization of the fuel compared to stock).
- Tighten the Starwheel so as to give minimal fueling short of interfering with adequate power.
- Run the smoke screw all the way out.
- Back out the main fuel screw to just before the point the truck can't get past it's own shadow.
- Use the EGT guage to keep the EGTs as low as possible (by light foot application)
* The AFC (automatic fuel control) is made up by the fuel pin, starwheel and smoke screw components.
Postby cummins4life875 » Sun Jan 10, 2010 9:49 am
i dont wanna have to switch injectors and fuel pin back out... i just wanna tune the pump to get 2+ mpg out of it
cummins4life875
Postby PToombs » Sun Jan 10, 2010 9:52 am
If you don't care about power, do what BC said.
I myself wouldn't be so radical at 1st. Back out the smoke screw, turn the star wheel up, and watch your right foot. Keep it at or under 65mph and step on it easy. Your 4.10's are killing you if you're blasting on the highway at 70 or 75.
Then change the fuel pin out, etc., if you're not happy with it.
Postby cummins4life875 » Sun Jan 10, 2010 9:55 am
no way to push 2-3 more mpg with the setup i got?
cummins4life875
Postby SNOOT » Sun Jan 10, 2010 9:58 am
converter...
1993 W350
SNOOT
Postby Begle1 » Sun Jan 10, 2010 10:01 am
Driving habits...
Postby Richie O » Sun Jan 10, 2010 10:01 am
I can stretch 18mpg on my 93 with a rag and 4.10's on a trip. It has 6x16's and a m+h fuel pin. Like Pete says easy on the go pedal is how I do it. I have not even bumped the timing yet either.
Postby cummins4life875 » Sun Jan 10, 2010 10:03 am
ive been easy this whole tank and im only at 200 miles got a qtr tank left.... ill get too 300 probably and fill it with 22-23 gallons
cummins4life875
Postby Tacoclaw » Sun Jan 10, 2010 10:12 am
Got any fuel leaks?
My truck is leaking fuel at the fuel heater and the AFC pin, and needless to say, I've seen a dramatic reduction in fuel economy.
Plus this is winter time. Between cold starts and high idle times, you're not going to see optimal idle times this time of year. It may even have something to do with the fuel mixture they use in the winter.
Postby cummins4life875 » Sun Jan 10, 2010 10:14 am
nope truck is very sound... runs good and no rust :D but no mpg
cummins4life875
Postby BC847 » Sun Jan 10, 2010 10:30 am
SNOOT wrote:converter...
It's a 5-speed. ;)
Postby Redneckintraining » Sun Jan 10, 2010 12:13 pm
I have a similar problem
89 W250 CTD
727
I used to get 18-20 MPG with the truck when it was stock,Now I get 15 with BHAF,Piston lift pump and HX35.With no tweaks to the pump..I have some power but not as much as id like,but crappy MPG..
Redneckintraining
Postby BC847 » Sun Jan 10, 2010 1:09 pm
Redneckintraining wrote:BHAF,Piston lift pump and HX35.
Those items alone would not contribute to lower MPGs. :?
Postby Remps » Sun Jan 10, 2010 1:31 pm
Cruise egt? Max boost? Maybe you have a small boost leak. Should be able to go 50 mph and stay under 600 F for better mileage. (Depends on elevation a bit) Or maybe the brakes are dragging?Oh and check out the Bully Dog pin for gouging.If it is grooved throw it out,grind your own,and maybe turn the fuel screw up and adjust the idle. I always got better mileage with the pump turned up.What kind of 80 hp injectors?
