VW gsk???
VW gsk???
Postby ccoxva » Sun Jan 17, 2010 7:24 pm
Am I wrong or do remimber someone on here putting the GS out of a vw ve pump in there pump for 4000 or 5000rpms???
1991 N/I 250
1996 Dodge 3500 Ex. Cab Dually 19.5's
ccoxva
Postby lectro_static » Sun Jan 17, 2010 8:58 pm
http://1stgen.org/viewtopic.php?t=7131
I believe some people cut loops off to get more rpm before defueling also
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby ccoxva » Mon Jan 18, 2010 6:10 am
Its been a while back but I remember about the volkswagon ve spring workin as a 5000 gsk?? :oops: coulda been dreamin too I've been known to do so frequintly.
1991 N/I 250
ccoxva
Postby burnt_servo » Mon Jan 18, 2010 10:03 am
the stock vw springs start to defuel in the 4200 to 4500 rpm range .
mild shimming of the springs and you are easily into 5500 to 6000 rpm range before defueling .
this is on a vw pump , i would expect that the govenor weights on both pumps to be the same , but you never know .
'93 w250 .... stock ...
burnt_servo
