fuel screw
fuel screw
Postby spencermumma » Thu Jan 21, 2010 7:57 pm
i have a 1990 dodge w250 5in stacks turned fuel screw one turn gauges on way but i cant get my idle speed to stay the same when adding more fuel any fixes with out sending it to be put on pump stand?
spencermumma
Postby DieselSharker » Thu Jan 21, 2010 9:16 pm
ummm...turn down your idle screw? that's a good fix. sorta hard to get to but it'll fix your idle problem.
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Postby soggy » Thu Jan 21, 2010 9:45 pm
If you have a dremel tool or something similar it makes it a lot easier
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby spencermumma » Fri Jan 22, 2010 12:29 pm
the only problem is when i look at the idle screw there is a gap and it doesnt look like its going to go away
spencermumma
Postby diesel freak01 » Fri Jan 22, 2010 1:21 pm
i think i had the same problem. i had to shim the pin where the two springs ride on (the pin is wore plum out) after i done this it let the idle spring release tension and would idle down.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby spencermumma » Sat Jan 23, 2010 6:36 am
i guess im not sure what pin your talking about is it actually down in the pump?
spencermumma
Postby PToombs » Sat Jan 23, 2010 8:03 am
On top. There are 2 throttle levers with a spring between them. It's an over load device, if the throttle goes too far, it won't over load the pump shaft. 1 lever is hooked to the throttle, the spring connects the 2 and the 2nd one drives the pump shaft. The pins the spring rides on wear, letting things get loose. The spring wears too.
Just look at the lever on the pump, and turn it, you will see what we are talking about. ;)
Postby spencermumma » Sun Jan 24, 2010 6:53 pm
thanks for all the help it worked!!!
1990 Dodge W250 5 inch stacks no muffler, Star wheel bottomed out, Smoke screw turned all the way, Fuel screw maxed, Denny T Fuel Pin, 2inch lift with 33x12.50 and alot more to come shooting for 450 horsepower any suggestions?
spencermumma
