Do adj. boost elbow fittings work?
Postby Moebiusgold » Mon Jan 25, 2010 7:38 pm
92 W350 DRW
Moebiusgold
Postby lectro_static » Mon Jan 25, 2010 8:08 pm
That is NOT an actuator what that does is bleed boost off so the actuator thinks its not making the boost it is supposed to be. In essence it lies about the amount of boost being made before the actuator opens.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby Tintacker » Mon Jan 25, 2010 9:50 pm
I had one of those on my '01 with an HX35 for over 100K miles. Worked great.
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
Postby Richie O » Mon Jan 25, 2010 9:54 pm
Could someone just plug the boost port on the turbo and plum the waste gate actuator hose to the intake on the engine? I would assume there would be a pressure drop from the turbo outlet to the intake on the engine. It might add a couple pounds of boost more that way before the wastegate actuator opens.
Postby lectro_static » Mon Jan 25, 2010 10:06 pm
Richie O wrote:Could someone just plug the boost port on the turbo and plum the waste gate actuator hose to the intake on the engine? I would assume there would be a pressure drop from the turbo outlet to the intake on the engine. It might add a couple pounds of boost more that way before the wastegate actuator opens.
I think you could but unsure how much of a drop there is, the bleeders allow you almost infinite adjustment. I had the same type of deal on an rx-7 and with a turbonetics 9psi wastegate I could easily make 40psi boost but ran it at about 15psi.
BTW the one I used was a simple air compressor regulator. They also make a "gillis valve" that will do the same thing with no creeping.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby Ace » Wed Jan 27, 2010 5:55 am
Mine runs about 2lbs. more on the turbo side. I have the W/M controller's boost coming off the turbo outlet and set to start spraying at 17psi. Flow indicator comes on at 15psi according to the boost gauge that sees manifold pressure.
Ace
Postby DZL_Damon » Thu Jan 28, 2010 9:11 pm
Used a similar product on my old Mercedes to cure a weak, 24 year old wastegate spring and worked like a charm. I could dial it in to wherever I wanted like a charm. It's just a check valve that needs to be opened by pushing against a spring. The tighter the spring, the more pressure needed for it to open, when that pressure is high enough, it will allow air pressure to work upon the normal actuator. There is a TINY bleed so that when you let off the throttle, the pressure in the actuator line will bleed off and reclose the wastegate. Like said, works like a charm, and real easy to dial in where you want the pressure setting at.
-93 W350,CC, DRW, A518, Pump maxed, DDP3, DennyT, 4" DP, black muffler stack with flapper. HE351cw, CoolerTubz, PS I/C, 4601HP elec. fuel pump, 205k
-89 D250, clean utility bed, TF727, new IP, 76k
-09 VW TDI 2.0L CR, ~45mpg, 20k
DZL_Damon
Postby BC847 » Thu Jan 28, 2010 10:30 pm
At the end of the day, the waste-gate is there to protect the turbo and keep it in it's MAP. Driving the actuator with that referencing the intake log could result in over-speeding the turbo. :)
Postby Richie O » Fri Jan 29, 2010 11:54 am
BC847 wrote:At the end of the day, the waste-gate is there to protect the turbo and keep it in it's MAP. Driving the actuator with that referencing the intake log could result in over-speeding the turbo. :)
Are you really concerned with over spinning the turbo? :lol:
