Looking for Exhaust System
Postby 93DodgeCummins » Thu Apr 15, 2010 6:25 pm
Does anyone know if there is anyone out there who makes a 4 inch turbo back exhaust for the 1st gen dodges? I know about stans but i was wondering if there was anyone cheaper.
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: Looking for Exhaust System
Postby peobryant » Fri Apr 16, 2010 11:18 am
Source Automotive makes one, but I believe it is priced similar to the Stans system. Expandit and Bully Dog make 4" systems with 3" downpipes for significantly less than the other systems, so you could look into that. A stock turbo has a 3" outlet anyways, so you don't need a 4" downpipe.
Postby 93DodgeCummins » Fri Apr 16, 2010 7:34 pm
yea but i want 4 inch up to the turbo back and just 3 inch where the turbo hooks up
93DodgeCummins
Postby FRadisi » Sat Apr 17, 2010 7:02 am
Check out http://www.farmboysdiesel.com, he has budget kits he puts together himself.
http://www.farmboysdiesel.com/servlet/t ... Categories
FRadisi
Postby BuckarooII » Tue Apr 20, 2010 11:50 am
I got my full aluminumized system 4" from the turbo back from Stans Headers http://www.stans-headers.com/diesel.htm they build a dam nice system when i put mine on my egts dropped 200 deg,
BuckarooII
Postby 93DodgeCummins » Tue Apr 20, 2010 8:47 pm
is it 4 inch all the way up to the turbo back and then 3 inch just at the turbo so it will fit?
93DodgeCummins
Postby peobryant » Tue Apr 20, 2010 9:04 pm
93DodgeCummins wrote:is it 4 inch all the way up to the turbo back and then 3 inch just at the turbo so it will fit?
I believe you can order the Stans kit with a 3" or 4" downpipe depending on your preference. The cheaper kits come with 3" downpipes. The downpipe is the piece that connects to the turbo, just incase you don't know.
Postby Begle1 » Tue Apr 20, 2010 9:34 pm
And the point of having a 4" downpipe on a turbo with a 3" turbine exducer is...
Postby peobryant » Tue Apr 20, 2010 10:00 pm
Begle1 wrote:And the point of having a 4" downpipe on a turbo with a 3" turbine exducer is...
Absolutely nothing. Some people do claim that going to a 4" downpipe dropped EGT's 50-100*, but I've never seen that to be the case personally.
Postby 93DodgeCummins » Wed Apr 21, 2010 5:25 am
all i wanted to know was if the downpipe was 4 inch up the the turbo back and connects to the 3 inch outlet on the turbo
93DodgeCummins
Postby peobryant » Wed Apr 21, 2010 1:11 pm
93DodgeCummins wrote:all i wanted to know was if the downpipe was 4 inch up the the turbo back and connects to the 3 inch outlet on the turbo
Unless I'm mistaken, no one makes a downpipe that starts at 3" and goes to 4".
Postby 93DodgeCummins » Wed Apr 21, 2010 2:11 pm
ok i thought that was how the stans exhaust was.
93DodgeCummins
Postby 1STGENFARMBOY » Wed Apr 21, 2010 2:54 pm
Mine is homemade it hooks to my factory turbo then about 1/2 in out goes to 4in,
couldn't tell any diff in the egt's but it did help the barking a little and sounds very nice
when you have about 18-22 lbs of boost and lift off the skinny. :lol:
Postby Richie O » Wed Apr 21, 2010 5:33 pm
Parker, you are mistaken. You can buy the Stans with a HX40 style or a H1C 3 inch hook up. If you have the 3 inch outlet it goes 4 inch about 1 inch behind the flange. Philip has a picture of it. I will hack into his photobuckett and look around. 8)
Postby Richie O » Wed Apr 21, 2010 5:39 pm
From Philips file.
And a 4 inch HX40 style that I have
