what will happen with more mods
Postby 91bluecummins » Mon Aug 02, 2010 7:19 pm
will a denny t fuel pin and a gsk make my trans slip with the other mods i have done
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: what will happen with more mods
Postby Richie O » Mon Aug 02, 2010 7:30 pm
It might. :bom:
Postby 91bluecummins » Mon Aug 16, 2010 2:48 pm
well i got the govonor spring on and i kept getting it off the notches it would slip over instead of 10 and 4 oclock position it would go to 12 and 6 oclock but i got it right next i thinking about getting a denny t pin
91bluecummins
Postby Begle1 » Mon Aug 16, 2010 7:57 pm
Torque is a lot harder on a transmission than horsepower; adding RPM will be less likely to hurt a transmission than adding fuel and low-end torque.
The governor spring may even help the transmission, as doing anything that can shift the power-band higher. Advancing your timing will as well, for instance.
Postby JQmile » Tue Aug 17, 2010 9:41 am
It will probably feel like it slipping, but it will probably just be flashing the converter. I've seen 300+ at the wheels on a stock trans and converter, it just depends how good of shape everything is in.
JQmile
