14mm head for a 4bt
14mm head for a 4bt
Postby jessejonassen » Sat Aug 14, 2010 7:36 pm
I just have to say this site is awesome so much info, Sorry if I mispell something, I am a redneck. I am wondering if the 14mm head can be had for a 4bt?
jessejonassen
Re: 14mm head for a 4bt
Postby JQmile » Sun Aug 15, 2010 7:29 pm
Paging KTA-Cummins?
JQmile
Postby KTA » Mon Aug 16, 2010 6:21 pm
I already answered a PM and said not that I know of.
Postby jessejonassen » Sun Aug 22, 2010 8:38 pm
I found one for a 4cylinder ve in canada, apparently they are custom made for seriously turned up vws, I have changed my own pump heads before, but I have never, understood what the k dimension is can anyone help me here. I have a good electric lift pump, this pump will not be maxed out, stock cam plate, I am just looking to get a little more than the 12mm pump. Is there any thing that I am missing except to make sure the internal pressure is right. You can get around 215 horse out of the ve pump without getting into it I am looking to get 240 to 260 I am spinning a hx35 with a 12cm housing. I have a 8cm bullseye housing for it. Will do the pump first then move on to the turbo what do you guys think? I am running a stock water aftercooler with a seperate cooling system. Thank you kta for responding.
jessejonassen
