drilling out banjo bolt holes
Postby 1badve239 » Sat Aug 21, 2010 9:05 am
On my banjo bolt would there be any performance gain if I drill out the holes on the bolt a size or two bigger? How about on the cover of the pump where the boost travels from the bolt to the fuel pin it looks like maybe I could drill it out a little bigger what are your suggestions? I have one more question what is the best way to mark my star wheel so I know the stock setting? Maybe permanent marker or will it not stay?
1992 dodge w250 5spd le club cab
fuel screw, full travel throttle. 5in dp, hx40
1993 ext cab w250, built auto, PODS hx40 pump work, 3200, fuel pin, full travel throttle, electric lift pump
1badve239
Re: drilling out banjo bolt holes
Postby JBradley500 » Sat Aug 21, 2010 10:11 am
i think drilling them out to a 5/32" or 11/64" bit will work fine. i did it to mine. 3/16" seems too big, its bigger than the chamfers on the stock bolt holes.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Postby Douglas » Sun Sep 12, 2010 2:59 pm
hey-Hey!!!,
I'd be most cautious on drilling the bolts; there needs to be enough strength to squish a copper seal washer. Now if the app can live with something softer as a seal...I'd still be careful.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
