Fuel syste........A 1000 or Kennys pulling parts?
Postby GLHS » Sun Aug 22, 2010 7:25 pm
Was ready to order an Aeromotive A1000 and filters today from Jegs then remembered Kennys Pulling Parts has a custom front cover with a hole to adjust the cam timing and an optional front mounted fuel pump.
Anyone have any experience with this setup? If it is streetable and if I have enough room for it up front, I think it would be good to have a mechanical pump that would pump more fuel as the rpms climb.
Or, should I just send Brian a PM? :lol:
GLHS
Re: Fuel syste........A 1000 or Kennys pulling parts?
Postby ellis93 » Sun Aug 22, 2010 7:38 pm
I don't know about a gear driven pump on our motors but a 60 series detroit sports them and I think cats do as well.
Postby JBradley500 » Sun Aug 22, 2010 7:57 pm
or just put a high pressure piston pump in it and regulate it... they will handle the power a ve or 12mm p-pump can make.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Postby soggy » Mon Aug 23, 2010 8:57 am
What are the specs on the gear/belt drive pump?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby Begle1 » Wed Sep 01, 2010 6:53 pm
I am so close to having a chain-driven ISX 300 PSI fuel pump mounted onto a scrap air conditioner... I just need a couple days home for a change.
But I got $2000 worth of intake and exhaust crap to put on too. I don't know what has priority. Probably the exhaust since thats bigger boxes taking up a lot more space.
