Twin turbo options
Twin turbo options
Postby 1badve239 » Thu Sep 09, 2010 7:58 pm
Hi guys, I currently have a single hx40 turbo and would like to upgrade to compound or twin, (I forgot the correct term) I would like to get a turbo from the junkyard off of like a semi or farm tractor etc. what should i look for? I'm upgrading too a 14mm head, electric lift pump, cam, valve springs, studs and big injectors. I would like to get started on looking for a turbo because I believe this will take some time. Thank you for any input ;-)
1992 dodge w250 5spd le club cab
fuel screw, full travel throttle. 5in dp, hx40
1993 ext cab w250, built auto, PODS hx40 pump work, 3200, fuel pin, full travel throttle, electric lift pump
1badve239
Re: Twin turbo options
Postby AHineman » Thu Sep 09, 2010 8:28 pm
The bottom turbo in my setup is a 75mm s400, part number 171702. I've read that it comes stock on 11.1L Detroit engines.
Postby delinquent » Thu Sep 09, 2010 9:10 pm
My vote goes to an HT3B. An S475 would be ok also, I just like the commonized HT3B
delinquent
Postby 1badve239 » Fri Sep 10, 2010 6:01 am
what does a ht3b come off of?
1badve239
Postby cumminz90 » Mon Sep 13, 2010 5:14 pm
I believe correct me if im wrong guys the ht3bs can be found on the N14 cummins at least the two dump trucks we have have that turbo on them hope that helps :D
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Postby oldestof11 » Tue Sep 14, 2010 9:06 pm
1badve, its compound. 1 turbo compounds the next turbo.
Twins are 2 of the same, like real twins. :D
Postby gobigorgohome » Sun Sep 19, 2010 10:06 am
cumminz90 wrote:I believe correct me if im wrong guys the ht3bs can be found on the N14 cummins at least the two dump trucks we have have that turbo on them hope that helps :D
if im thinkin of the same turbo that you are, that is one BIG turbo lol we see n14s in the shop i work at all the time :D
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Postby dvst8r » Sun Sep 19, 2010 10:41 am
I have an HT60 that I pulled off an N14, I thought the HT3B's were off the older 855's?
Though an HT60 will work fine as well.
1990 W250 non ic'd. Under the knife again.
dvst8r
Postby PToombs » Sun Sep 19, 2010 5:44 pm
I was looking at an HT3B today on an older 855. It came out of an '86 Diamond Reo. The exhaust housing looks huge! My buddy also had a HT4B sitting in the parts trailer. That looked waaaaayyyy too big. :cry:
Postby gobigorgohome » Wed Sep 22, 2010 9:43 am
:D that HT60 he is talkin sbout gives off a REALLY good whistle lol but thr dang thing on the exhaust side has to be close to a foot across!!!!! buut it spools very nice:)
gobigorgohome
Postby rattlebox93 » Sun Oct 03, 2010 9:25 am
AHineman wrote:The bottom turbo in my setup is a 75mm s400, part number 171702. I've read that it comes stock on 11.1L Detroit engines.
no detroits use a k31 with is a cousin not brother to the a5000
rattlebox93
Postby rattlebox93 » Sun Oct 03, 2010 9:28 am
im pretty sure a friend of mine has a ht3b it was off of an old 280 or 290 cummins in a single axle daycab i tried selling it for him before i think he wants 400
rattlebox93
Postby AHineman » Sun Oct 03, 2010 2:03 pm
http://www.fleetsource.com/Detroit_60_Series_Turbo_171702_Factory_New_No_Core_p/171702.htm
I guess its just an upgrade for the Detroit, I thought it was stock on some.
Postby SNOOT » Sun Oct 03, 2010 4:13 pm
https://turbodaves.com/Borg_Warner.html
1993 W350
SNOOT
Postby AHineman » Sun Oct 03, 2010 6:31 pm
Lots of cool stuff there for sure!
I actually got mine from http://www.turbosupply.net to the tune of $552.
The fleetsource link just had a better description. Turbosupply is a good place to get stock unmodified turbos if you know the part numbers, no special stuff.
