Water/meth Injection!!!
Postby 91_CUMMINS » Sat Sep 11, 2010 8:01 am
Hey guys I just got a snow kit for my truck and I have a set of Tim worlines coolertubz but I'm just wondering of they are thick enough to tap into for the injector nozzles!! Or do u need to use a weld on bung? I'd like to just drill and tap if it's possible?? Has anyone done this? Maybe Tim could answer my question!?
91 RAM 350, 75HP POD's, HX44, 600HP southbend, ARP head studs, custom intake, 4"exhaust, 3"stainless coolertubz, maxed VE, fuel pin, 3200, snow performance stage 2, boost/pyro guages, 2" lift, 33's/16's, What next?
91_CUMMINS
Re: Water/meth Injection!!!
Postby oldestof11 » Sat Sep 11, 2010 12:16 pm
Ask Tim. :alien:
Postby TWorline » Sat Sep 11, 2010 12:46 pm
Yes the 16ga. is thick enough to drill and tap. I always suggest installing the injectors right after the intercooler, the mist has more of a chance to mix thoroughly with the air before it hits the head and if there is a malfunction in the injection system it will just run into the intercooler rather than filling up a couple of cylinders.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby collegekid » Sun Aug 07, 2011 4:13 pm
Are the stock IC tubes thick enough to drill and tap, or is welding a bung on them necessary?
collegekid
Users browsing this forum: No registered users and 77 guests
