New(er) performance needs
Postby matchew » Wed Oct 06, 2010 5:09 pm
Got the truck running again. 130,XXX mile 12v and A518 trans, clean runs good. Put my +40 injectors in and ground my fuel pin. Pins the 30lb gauge but doesn't seem to be as fast as the old motor. Turned both smoke screw and star wheel about 2 turns down and the power screw 2.5 turns in, no run-away...got some smoke and will chirp the 37s from a stop. Seems to run a lot better, how much more could I get out of it before I need to worry about the tranny? I REALLY need to get my EGT gauge hooked up, all it has is the plug for the probe and 2 brass studs(mounting?)...I've plugged it in but no workie...does it need 12v?
92 1 ton, 7" lift 37 military MT's on Hummer Alcoas, HE341, 4" downpipe to tailpipe, killer front bumper, 14mm H+R, +40 injectors, 03 dodge seats, loud tunes. 'Custom' Rustoleum paint.
matchew
Re: New(er) performance needs
Postby ellis93 » Wed Oct 06, 2010 7:30 pm
If the probe uses wires then the brass studs will need power on one and ground on the other.
Postby matchew » Thu Oct 07, 2010 5:49 am
I was hoping that was the case. I'll hook it up this weekend. Anybody else?
matchew
Postby oldestof11 » Thu Oct 07, 2010 2:47 pm
Hold it.
I have found with a 2 post system, it has no need for a power line. It reads resistance. NOw if it has 3 posts, you have ground, power, sensor.
Postby ellis93 » Thu Oct 07, 2010 5:25 pm
How does that work? Most sensors use some sort of voltage. How would u check it.
Postby matchew » Thu Oct 07, 2010 7:21 pm
I'm thinking my probe must be bad. Wired the 2 studs and put them on the battery....you know, those wires would glow if the sparks didn't make me jump! I need a new probe AND the plug that goes into the back of the gauge. VDO here I come!
matchew
Postby oldestof11 » Sat Oct 09, 2010 2:49 pm
MY stewart warner read was a no power pyro.
Postby ellis93 » Sat Oct 09, 2010 3:09 pm
Was it made like a manual water temp gauge.
Postby PToombs » Sat Oct 09, 2010 5:29 pm
My DiPricol pyro is the same way. The probe somehow makes current to run the gauge. The only power is for the lights.
No capillary tube on it, like a temp gauge, only wires.
Postby ellis93 » Sat Oct 09, 2010 6:06 pm
That's a new one on me :|
