oldestof11 wrote:P, Non-IC are 9mm big. Anything after 91.5 is 7mm.
All the Non-IC have to make them bigger is "extra" material.![]()
ellis93 wrote:Might be problems inside the pump . I have stock injectors and have only done the afc mods and get some smoke now.
Ptothej wrote:oldestof11 wrote:P, Non-IC are 9mm big. Anything after 91.5 is 7mm.
Sorry I dont think I quite followed you there.
JBradley500 wrote:Ptothej wrote:oldestof11 wrote:P, Non-IC are 9mm big. Anything after 91.5 is 7mm.
the tips on the non-intercooled injectors are 9mm in diameter... the intercooled injector tips are 7mm in diameter...same thing for the hole in the heads that the tips go through so the 9mm injectors (non-intercooled) wont fit into a 7mm (intercooled) head.
Ace wrote:I think the smoke screw and starwheel become pretty much useless with the fuel screw turned in.
