Maxed injectors?
Maxed injectors?
Postby Ptothej » Thu Oct 21, 2010 7:02 pm
Hey, take a look at my signature.. so Im using the power screw to adjust the idle, but have no idea how many turns which way it is, it seems like when I backed off the smoke screw and star wheel earlier this year it didnt do anything.. then within the past two days Ive cranked the smoke screw all the way and bottomed the star wheel out, and still nothing that Ive noticed, and if Im wrong it has been very slight changes. could the injectors be maxed? If so, is it worth while to put some non intercooled ones in? (not wanting to spend money on it that way, and the injectors are free and in an engine out back of my dads shop) thanks for your help as always!
P.S I also remember after playing with the power screw that my fuel pin didnt do much difference either.
'92 W250, 5spd, reg. cab, 2" lift, 4" dp, 4"exhaust no muffler, smoke screw bottomed out, star wheel bottomed out, full power screw maxed, BD fuel pin, BD 16cm housing (30psi), K&N air filter with a modified factory air box
Ptothej
Re: Maxed injectors?
Postby ellis93 » Thu Oct 21, 2010 8:40 pm
Nonintercooled injectors won't fit intercooled heads from what I've seen. I would check the afc tube and make sure its not cracked. Put some grease on ur fuel pin and see if its moving.
Postby Ptothej » Fri Oct 22, 2010 7:16 am
I think I slightly remember hearing something like that... yes the fuel pin is doing what it should. I do remember changes when all I played with was my smoke screw, star wheel and fuel pin, but since I jacked up the power pin for the idle, I have not noticed any changes by playing with those other settings. In case the non intercooled injectors would work.. Im just looking for some more fuel basically down low to get my boost numbers higher in the lower rpms.. up top is just fine.
Ptothej
Postby ellis93 » Fri Oct 22, 2010 7:50 am
Might be problems inside the pump :(. I have stock injectors and have only done the afc mods and get some smoke now.
Postby oldestof11 » Fri Oct 22, 2010 1:25 pm
P, Non-IC are 9mm big. Anything after 91.5 is 7mm.
All the Non-IC have to make them bigger is "extra" material. :lol: :lol:
Postby Ptothej » Fri Oct 22, 2010 1:38 pm
oldestof11 wrote:P, Non-IC are 9mm big. Anything after 91.5 is 7mm.
Sorry I dont think I quite followed you there.
Ptothej
Postby Ptothej » Fri Oct 22, 2010 1:40 pm
ellis93 wrote:Might be problems inside the pump . I have stock injectors and have only done the afc mods and get some smoke now.
The pump is a nwere rebuilt unit, and I do smoke if I tromp on it, but the smoke doesnt lessen or increase with my adjustments...
Ptothej
Postby JBradley500 » Fri Oct 22, 2010 1:48 pm
the tips on the non-intercooled injectors are 9mm in diameter... the intercooled injector tips are 7mm in diameter...same thing for the hole in the heads that the tips go through so the 9mm injectors (non-intercooled) wont fit into a 7mm (intercooled) head.
340hp/662tq (8/24/12)
JBradley500
Postby Mark Nixon » Fri Oct 22, 2010 4:24 pm
Not to mention the pistons in an Intercooled engine have the wrong bowls for the Non-Intercooled injector's spray angle.
The intercooled uses a narrower spray angle.
Postby Ptothej » Sat Oct 23, 2010 8:01 am
I appreciate everyones input! Now I know more about the injectors. I havent heard much about your guys's ideas on my truck having the injectors maxed out though, has anyone else come across this, or do I do have a pump issue?
Ptothej
Postby Kiddspeed » Thu Oct 28, 2010 9:09 pm
mine does the same it seems like my injectors are maxxed too. I know what youre talking about.
Kiddspeed
Postby Ptothej » Sun Oct 31, 2010 9:32 am
Oh wicked, what are your poump settings at? I just found out that my fuel screw was right at the bottom out point, I might of got 1/4 turn out of it.. so now all my pump settings are maxed!
Ptothej
Postby Ace » Thu Nov 04, 2010 9:56 am
I think the smoke screw and starwheel become pretty much useless with the fuel screw turned in.
Postby Ptothej » Sat Nov 06, 2010 10:58 am
Im thinking you are absolutely right there.
Ptothej
Postby JBradley500 » Sat Nov 06, 2010 5:04 pm
Ace wrote:I think the smoke screw and starwheel become pretty much useless with the fuel screw turned in.
im pretty much thinking the same thing. i think the settings on the afc stuff have to be more drastic to see a change once the power screw is all of the way in... bigger injectors too :D
my starwheel went from all the way down to being up high enough to bind my fuel pin and that really seemed to help spool-up drastically.
JBradley500
