he351/ht60
he351/ht60
Postby 913 Cummins 89 » Thu Dec 09, 2010 8:03 am
the HT60 is a 73.5 comp. 88 turbine and a 23 exhaust i was wondering if this would be a goos setup with some 8x11 im in the process of buying. i want to eventually get bigger sticks as i will be going to a 14mm ve in the end. will this twin setup support that kinda power or do i need to get a better big turbo. i have a second gen intercooler and the he651 on my truck already
Thanks,
913
913 Cummins 89
Re: he351/ht60
Postby oldestof11 » Thu Dec 09, 2010 2:52 pm
I think 5x18's or 6x16's would be a better match of injectors.
Now if it was a HX50 or 55, then yeah.
Of course, I am gonna try a H2E (63/73/17).... As a single...
Re: he351/ht60
Postby JBradley500 » Thu Dec 09, 2010 2:55 pm
I think it will work great LOL ;)
Honestly i almost bought a ht60 like 6 months ago to do a set of twins with but i found out it wasnt a real holset so i told them to keep it.
-end of useless post-
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Re: he351/ht60
Postby oldestof11 » Thu Dec 09, 2010 3:43 pm
I assume they are your injectors J?
Re: he351/ht60
Postby Remps » Thu Dec 09, 2010 4:44 pm
I wouldn't waste money on 8 hole sticks. Might as well buy PODs, they'd probably make more power. :/
Re: he351/ht60
Postby JBradley500 » Thu Dec 09, 2010 5:16 pm
Yeah they might be mine.
Why wouldnt you waste your money on 8 hole injectors? Early common rails come with 8 hole injectors. Think they should go to PODs too?
JBradley500
Re: he351/ht60
Postby Remps » Thu Dec 09, 2010 5:52 pm
Injectors with 4,5,or 6 holes have already been proven to work better with the VE pump. Not sayin 8 holers don't work, they just have never made as much power as the others. Yet. And when you have 25 000 psi of fuel pressure to play with, like a common rail, 8 holers probably work great.
Re: he351/ht60
Postby JBradley500 » Thu Dec 09, 2010 6:00 pm
The ones hes getting run pretty well honestly. You can see what i made with them on Scheids dyno that was running about 19% lower on HP than Dunbars. That was with a boost leak (lost 6psi at peak), less timing than i have now and a really sloppy AFC setup. I think i could have made 375 on dunbars pretty easily if that 19% number was a constant for every truck.
JBradley500
Re: he351/ht60
Postby 913 Cummins 89 » Fri Dec 10, 2010 11:18 pm
i sure hope they work fine i dont know if the will be enouh for twins but we will see
913 Cummins 89
Re: he351/ht60
Postby bgilbert » Sat Dec 11, 2010 7:14 am
J you'll remember next year what dyno to run on! haha!
Bill Gilbert
bgilbert
Re: he351/ht60
Postby JBradley500 » Sat Dec 11, 2010 9:18 am
bgilbert wrote:J you'll remember next year what dyno to run on! haha!
haha yeah for sure, it would be nice to have a number to directly compare with. i hope to have a better overall setup by then too. the truck will still look like a beater though :rock:
JBradley500
Users browsing this forum: No registered users and 62 guests
