What to do?
What to do?
Postby lazyjoe » Mon Dec 13, 2010 11:48 am
Ok guys, started installing parts on my 93, W350 a couple of weeks ago. Pulled my turbo off, to install a HX35, W/ a 16c, that I've had for awhile now. Had'nt paid much attention to the turbo on the truck, (assumed it was stock). :oops: Got it off, and it is an H1C, W/ a 14c, wastegated. Now I don't know what to do. I've been looking around, and found a HX40 impeller and housing. Will it fit, and is it worth it? Plans for the truck, piston lift pump, 366 spring, 2nd gen. intake horn. Not sure on injectors. The truck will eventually have a deweze bale bed. Pull stock, and hay trailers. And be driven daily.
Thanks,
Joe
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
Re: What to do?
Postby ellis93 » Mon Dec 13, 2010 12:21 pm
If I were to upgrade a turbo, I'd do the H1C. Simply because it the smaller of the two you have. Have you looked at the tag on the comp housing to see if its a WH1C. If it is then it has a 56mm inducer and not the 54mm that on the H1C. If in fact it is the WH1C then its basicly the same as a HX35.
I've just went through this same thing.
As far as the 60mm upgrade it is really nice. I've not seen 1100 on the egt gauge in a while.
Re: What to do?
Postby Douglas » Mon Dec 13, 2010 5:46 pm
hey-Hey!!!,
The H1C housing will fit your HX35. If the HX has 8 blades on its compressor it is nearly the same as the H1C you've taken off. If it is the 7-blade it is a slightly better upgrade; it will flow a bit more( 60 lb/min v. 52 lb./min ). It will also spool a bit faster with its smaller diameter compressor OD is 77 v. 83 mm. Worth wrenching on if it is in your hands already. For a baby H1C it is much more worthwhile.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: What to do?
Postby lazyjoe » Wed Dec 15, 2010 10:40 am
ellis93 wrote:Have you looked at the tag on the comp housing to see if its a WH1C. If it is then it has a 56mm inducer and not the 54mm that on the H1C. If in fact it is the WH1C then its basicly the same as a HX35.
ellis, it is a h1c, not a wh1c. Where did you get your 60mm at?
Douglas wrote:If the HX has 8 blades on its compressor it is nearly the same as the H1C you've taken off.
Douglas, they are both 8 blades.
lazyjoe
Re: What to do?
Postby ellis93 » Wed Dec 15, 2010 11:15 am
Bought from here.
http://www.gillettdiesel.com/
They'll hook u up.
I bought mine for 250. I also got a rebuild kit for the turbo. Its really simple to do and was not much money.
Re: What to do?
Postby lazyjoe » Wed Dec 15, 2010 11:42 am
ellis93 wrote:Bought from here.
Thats where I was looking. Did you get your rebuild kit there to?
lazyjoe
Re: What to do?
Postby ellis93 » Wed Dec 15, 2010 1:36 pm
Yes sir. E mail them what you want and they'll mail you back a price. Dude I talked to was named Rick I think.
