HT3B
HT3B
Postby ellis93 » Mon Dec 13, 2010 12:26 pm
Is it worth hangin on to and would it work in a compound set up. What should I pair it up with. :?:
Re: HT3B
Postby fatty » Mon Dec 13, 2010 1:01 pm
Yes. You could run it with the turbo you have now.
Re: HT3B
Postby ellis93 » Mon Dec 13, 2010 1:11 pm
With the huge flang it has how would u adapte it and where would u get the parts to put it together. I know nothing about this kinda stuff. Anyone know of some info that explains compound turbos.
Re: HT3B
Postby 913 Cummins 89 » Mon Dec 13, 2010 5:04 pm
i wish i had one of these laying around as i would make me a nice compound set up. but to adapt it i personally would make my own flange that was i belive 6x6 inches (not sure) with a 4" whole on the middle to weld my down pipe to
913 Cummins 89
Re: HT3B
Postby PToombs » Mon Dec 13, 2010 5:58 pm
I have the same turbos as you, I was going to do a twins setup too. There's a guy in Connecticut that builds twins and triples sets, he wanted $1200 to build a set for me with my turbos. Only problem is he doesn't have a jig for a 1st gen, he needs my truck for a week to do it. Did I mention he's 5 hours away? :cry:
Re: HT3B
Postby ellis93 » Mon Dec 13, 2010 6:58 pm
Man that sucks. I'd break out in hives if my truck was 5hrs away and they're to keep it a week.
This is really just a feeler anyway. I thought I'd see what ya'll think and maybe figure out how to do it.
How much fuel would I need to push to get that turbo to spin up. It would need to be more than the stock setting right?
Re: HT3B
Postby ellis93 » Mon Dec 13, 2010 8:36 pm
Look at this Mr Toombs.
http://dieselpowersource.com/index.php? ... duct_id=57
It comes with everything. It was said ,in another forum by other people, to work on first gens. They were however talkin about putting 5" exhaust out the back and how it could not be done. Why would you need that any how. :?: :? I really need some schoolin here.
Re: HT3B
Postby oldestof11 » Tue Dec 14, 2010 3:48 am
Stomps setup is a HX-35/HT3B...
Re: HT3B
Postby Remps » Tue Dec 14, 2010 4:52 am
I thought it was HX40/HT3B?
Re: HT3B
Postby JBradley500 » Tue Dec 14, 2010 7:05 am
Remps wrote:I thought it was HX40/HT3B?
me too
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Re: HT3B
Postby ellis93 » Tue Dec 14, 2010 7:13 pm
How much fuel would I need to make this thing spin with the turbo I have on the truck.
Re: HT3B
Postby PToombs » Tue Dec 14, 2010 7:58 pm
Ellis, I liked this part of the ad, DOES YOUR CUMMINS RUN SO HOT IT'S SCREAMING FOR MERCY?
I didn't like the $3k price tag!
You allegedly can't put a 5" pipe past the transfer case, that's what they mean. The big turbo is probably set up with a 5" outlet. I don't have to worry about that, no TC. :mrgreen:
Re: HT3B
Postby ellis93 » Tue Dec 14, 2010 8:03 pm
Wonder if they ever thought of ovalling the pipe as it passes the tc.
Re: HT3B
Postby PToombs » Tue Dec 14, 2010 8:14 pm
It needs to be more of a triangle to max out the space. I've heard of a few guys leaving the small piece of the cross member out to run the exhaust thru. I don't like that idea! :shock:
Re: HT3B
Postby PRINCETON_JAKE » Wed Dec 15, 2010 6:07 pm
That is a good turbo for a compound setup, If you were asking as a single charger, NO it would never spool. I'm building a kit right now for a first gen hx35 or wh1c over the ht3b. im planning on building multiple kits, i want to be able to sell a kit or individual parts at a fraction of the competions prices.
Oh the ht3b used a "T6" flange, ebay has flanges pretty cheap.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
