6.0 or 7.3
6.0 or 7.3
Postby lazyjoe » Fri Jan 14, 2011 3:05 pm
So which flows better. A 2003 6.0 powerstroke intercooler. Or a 7.3. There's a guy trying to sell one, claiming the 6.0 does.
Joe
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
Re: 6.0 or 7.3
Postby burnt_servo » Fri Jan 14, 2011 3:14 pm
are they both aluminum ? are they both the same size , ..... meaning does the 6.0 fit on a first gen easily ?
the aluminum 7.3 cooler fits on a first gen , i assume the plastic 7.3 one fits too .
the aluminum ones are much stronger and easily repaired .
if the 6.0 cooler is plastic and /or doesn't fit a first gen , it doesn't matter if if flows more or less than a 7.3 cooler .
'93 w250 .... stock ...
burnt_servo
Re: 6.0 or 7.3
Postby Richie O » Fri Jan 14, 2011 3:14 pm
I have heard a 7.3 will fit better in our trucks. Maybe the 6.0 is bigger and will flow more, but will it fit in our small area?? I know my 7.3 cooler just fits between the frame and the hood latch area.
Re: 6.0 or 7.3
Postby Richie O » Fri Jan 14, 2011 3:15 pm
And Burnt servo beat me to it. Bloodshot eyes and all. :D
Re: 6.0 or 7.3
Postby lazyjoe » Fri Jan 14, 2011 3:23 pm
Well I know pics are deceiving . But this is what it looks like. Have'nt talked to him yet.
http://images.craigslist.org/3k13o43pe5 ... e41deb.jpg
lazyjoe
Re: 6.0 or 7.3
Postby huntinguy » Fri Jan 14, 2011 7:08 pm
6.0 has plastic end tanks. I wouldn't get it.
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Re: 6.0 or 7.3
Postby lazyjoe » Sat Jan 15, 2011 9:04 am
Ok, thanks guys. I think I'll leave it alone.
Joe
lazyjoe
Re: 6.0 or 7.3
Postby peobryant » Sat Jan 15, 2011 11:46 am
I think there was a guy on DTR that put a 6.0 'Stroker cooler in his 1st gen. From what I recall (which isn't much these days, and I'm not even old) he had to put a lot of work into it, and fabricate a lot of parts. Maybe it was a 3rd gen intercooler though...
Regardless, I'd stick with the 7.3 intercooler. Proven to work good, and not *that* hard to install.
Re: 6.0 or 7.3
Postby Deathrod » Sun Jan 16, 2011 8:27 am
yup 6.0's are plastic and huge......it would be a PITA to put one into a first gen....if i recall right they are super tall
Deathrod
Re: 6.0 or 7.3
Postby Deathrod » Sun Jan 16, 2011 8:31 am
oh...the original question.....I would imagine 6.0's flow better....technology will do that for ya!
Deathrod
