Tailgate lights dim
Tailgate lights dim
Postby brianjbell » Tue May 01, 2012 8:11 pm
I have a '92 D350. Just installed new LED lights on the tailgate and noticed tonight that they are really dim. Can someone tell me where the ground is located so I can clean and tighten it? Also, any other stuff that I need to check?
brianjbell
smoke screw?
Re: Tailgate lights dim
Postby PToombs » Wed May 02, 2012 5:38 pm
Where do you have it grounded? The main ground for the tail lights is just inside the drivers side of the frame in the rear. Just behind the crossmember is a bolt with the wire on it.
Postby brianjbell » Wed May 02, 2012 6:29 pm
I haven't changed anything from stock, but that's not to say that someone else did before I got the truck. Do the tail lights and the tailgate lights ground to the same place?
brianjbell
smoke screw?
Postby PToombs » Thu May 03, 2012 6:09 pm
They shouild, they get power from the same place. Everything is joined right there in the back corner. I don't have my FSM right handy to look for ya.
Postby revemup15 » Thu May 10, 2012 7:26 pm
What color is the ground wire
94 p-pump
revemup15
Banned
Postby PToombs » Sat May 12, 2012 6:13 pm
Black. You can't miss it, it's the one with an eye on it bolted to the frame. ;)
Postby firstgenjunkie » Sun May 13, 2012 8:23 am
Did you connect any type of load to the circuit? LEDs draw so little power that they'll be dim. If your instrument panel turn signal indicators are light I'll bet that's it.
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
Return to Electrical
